Old 10-19-2015, 05:43 PM   #1
2015 23' FB Flying Cloud
Vancouver , British Columbia
Loss of Control From Brake Binding?
We have experienced a couple of scary situations where our 2015 Flying Cloud 23FB, towed by our 2014 VW Touareg, started swinging wildly from side to side. First time was having just left home and gotten onto the freeway - long, slow bend to the left at about 40 mph. Second time was after an hour on the freeway, going downhill at about 60 mph. Both times we had no control - difficult to drive "into" things as it kept going from side to side. Truly thought we might flip.
My father thinks one of the brakes on the (dual axle) AS is binding. Any other ideas, before I take it to our (lousy) dealer?
FlyinNitwits is offline   Reply With Quote
Old 10-19-2015, 05:57 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
What type of sway control are you using?
Old 10-19-2015, 06:18 PM   #3
1981 31' Excella II
New Market , Alabama
You need sway control and when you get into a sway situation you want to use the manual lever to apply the trailer brakes only. You have a small car and a big trailer. The trailer is going to wag the dog if you don't have good sway control.
Perry
Old 10-19-2015, 06:20 PM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
What kind of hitch? It sounds more like a hitch setup problem to me. I would expect it to stay straight even if a brOke locked.
Bill M. is online now   Reply With Quote
Old 10-19-2015, 06:41 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Sounds like somethings wrong with your weight distribution hitch or setup, too light load in front or too heavy load in back of Airstream, or too heavy load in back of the Touareg. Or all these conditions.
The downhill situation adds the trailer trying to overtake the truck to the above conditions, making things worse. And stepping on the brakes going downhill can make it even worse, especially if there is not enough gain set on the brake controller.
I think you need some help setting up the weight distribution and loading the trailer to start with.
Doug and Cheryl
Old 10-19-2015, 06:48 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
One time would be enough, get a larger tow vehicle, then check your plug, both ends. Jack the trailer up, spin the wheel, have someone hit the brake controller ....
Old 10-19-2015, 06:58 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
This recommendation might get me booted from the forum... . But get yourself a Hensley designed hitch and say goodbye to sway forever.
Not really cheap, but a lot cheaper than a new tow vehicle.
It wasn't your brakes doing anything, it was the trailer. Airstreams have a lot of length behind the rear axles, once oscillations get the hint of a start they increase like a pendulum.
Brevi tempore!
Old 10-19-2015, 07:58 PM   #8
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I bet your hitch is poorly adjusted. Are you using a weight distributing hitch? Find a competent dealer (which may be hard) or learn how to adjust it yourself.
Find a thread here for the brand of hitch you are using. You'll learn a lot about how to adjust the hitch, and can ask questions. A picture of the hitch showing how your rig sits when hooked up will be helpful.
The gold standard for judging if a hitch is adjusted right it to weigh the rig on three-section truck scale--CAT brand or other. There are lengthy discussions elsewhere on Airforums. The basic idea is to weigh three times: Once just your tow vehicle, once with the rig hooked up but the weight distribution not applied, and once hooked up WITH the weight distribution hooked up.
SSquared is offline   Reply With Quote
Old 10-19-2015, 08:05 PM   #9
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Hitch setup.
If not able to resolve, (your dealer should be able to resolve, but if not, maybe call CanAm RV in London Ont for suggestions)
If that doesn't work, a Hensley or Propride hitch should make for relaxed, towing, but more spendy!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-19-2015, 08:09 PM   #10
JimGolden's Avatar
1977 31' Excella 500
CG, then Hitch, then Tow Vehicle
I think Dkottum hit on it....
It sounds like your trailer is tail heavy. That makes them inherently unstable. A fancier hitch might mask it, or a dump truck might muscle through it, but the real solution is to get the center of gravity correct.
A trailer needs to have it's CG located somewhere around 10-15% ahead of the centerline of the axles. The "real world" way to equate this is to have about 10-15% of the trailer's weight on the tongue. So say your trailer weighs 8000lbs, you'd want somewhere between 800 and 1200 lbs on the tongue.
I once saw a guy pulling a flat bed equipment hauler trailer with a Bobcat at the back of it, so that the trailer was very tail heavy. He was oscillating a little back and forth. I came up beside him and all of a sudden the oscillations got crazy. I gunned it and got ahead of him, just as the 16' flat bed tried to do a 180....it came clear around so that the tail lights were going down the road by the pickups headlights, it then rotated up and over the top, over the guard rail, and rolled the whole rig. Guy was lucky and didn't get hurt, but trashed his truck, trailer, and Bobcat.
Once the weights are located properly (i.e. don't put your blacksmith tools in the back of the trailer, etc.) and you get that worked out, then you can look at getting a Pro-Pride and a Kenworth
Yes, I tow with a crew cab long bed Dodge 2500 Cummins so I can joke about dump trucks
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 10-19-2015, 08:14 PM   #11
2007 22' International CCD
Ditto on verifying weight distribution in the AS and tongue weight. A fancy hitch of any sort will not help if the AS is tail heavy. It's a wreck waiting to happen.
I make darn sure with a Sherline tongue weight scale that I have 15 % on the hitch, then set up the ProPride WD. That will help basic stability. The rest is magic...and a big chunk of change to avoid the white-knuckle ride like that described....
KE4GNK/AE
Old 10-19-2015, 08:26 PM   #12
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Likely the weight of the towed load was pushing the tow vehicle in a down hill situation. This pushes the towed vehicle slightly and the towed vehicle resists. The resistance will cause the trailer to slow down and induce sway as the process repeats it's self until the towed vehicle speeds up or the towed load slows down.
>>>>>>>>Action
Old 10-19-2015, 09:05 PM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Why wouldn't good stiff SWAY Control help control or stop the SWAY? Someone learn me up on that.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 10-19-2015, 09:10 PM   #14
dkottum's Avatar
Trailer Sway Causes:
Trailer Sway Causes
Doug and Cheryl
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Intermittent brake loss problem solved 63air Brakes & Brake Controllers 2 07-27-2009 09:32 PM
Loss of control questionnaire Inland RV Center, In Hitches, Couplers & Balls 3 02-17-2009 02:10 PM
Loss and found suekozin Insurance & Claims 10 01-21-2003 05:28 AM
