Old 06-27-2014, 01:12 PM   #1
I tow where I'm told.
MrRivet's Avatar
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland , Florida
Loaded Brake Assembly Replacement
Time for brakes on the 28' International and I am going to buy the pre-loaded brake assemblies. What are everyones thoughts/experiences on upgrading to the self adjusting assemblies and upgrading to the 7,000 lb. capacity rating?
MrRivet is offline   Reply With Quote
Old 06-27-2014, 02:03 PM   #2
justretired's Avatar
2012 27' FB Classic
Jamestown , Rhode Island
I replaced one brake assembly in June. Only problem I had was getting the drum off, it takes a 36 mm socket, would not budge at first, added a little heat airgun did the rest. Used a Dexter 7000 set up. Works nice now.
justretired is offline   Reply With Quote
Old 06-27-2014, 03:10 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Go for the self-adjusters and never look back.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-27-2014, 03:11 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure I would suggest the self adjusting brakes. That may lull into forgetting to remove the drums to check the magnets and you will loose the brakes and destroy the drum. Adjusting the brakes is not worth that.
If you change the rating make sure they will fit the current drums. Brake capacity is a function of diameter and width of the shoe.
2004 Excursion 4x4
Old 06-27-2014, 06:40 PM   #5
MrRivet's Avatar
1948 22' Liner
1963 22' Safari
Oakland , Florida
Have always been religious about re-packing bearing and checking the brake components yearly. Guess it was a habit from my boating days. Bearings and tires will leave you on the side of the road quicker than anything. Saw on other threads where owners had installed brake assemblies rated for 7K lbs. Where the shoes were made with a more aggressive compound. Thought I would look at all options for brake replacement before I pulled the trigger.
Safe travels!!!
Tim
Replacement Brake Assembly Jake Brakes & Brake Controllers 19 07-27-2020 03:17 PM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 03-15-2011 01:50 PM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 02-20-2011 07:30 PM
used rv A DIESEL LOADED AIRSTREAM SLIDE FREE DELIVERY Sused rv A DIESEL LOADED AIRSTR eBay Watch Airstreams on eBay 0 01-24-2011 07:40 PM
Brake light assembly replacement Stinky Lights - Interior & Exterior 0 10-27-2003 04:59 PM
