Old 11-20-2014, 01:40 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Brakes will lock up in reverse when they are too far out of adjustment. They will cam over and lock. This can happen when moving forward as well. But it will show up in reverse first.
Old 11-28-2014, 09:06 PM   #16
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Update- I adjusted all four brakes and the left rear still grabs. We had plans to travel for the holiday (without the trailer) so we were in a bit of a time crunch. I tested the brakes on the way to storage, so i'll have to pull it early for Canopener or before to tear down that wheel and see what is going on.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-28-2014, 07:15 PM   #17
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
I just spoke with a fellow the other day who had the same problem. His turned out to be the wrong part installed in the brake,the correct part number, but there is evidently a error in the book. With this part in it the brake will lock when applied, and not release. You may have to compare the parts with the brake on the other axle. Hope this is some help. Rolland
Rolland is offline   Reply With Quote
Old 12-28-2014, 08:20 PM   #18
Thanks Rolland,
Do you know what part it was?
I started another thread to discuss the possibility of centering the backing plate on the axle as I found some info on an SOB site that indicated that could be the problem. I have since removed the drum and inspected the brake assembly without finding any problem. I did notice that this brake was dragging a little more so I backed off the adjustment. We are going to the Canopener Rally in January so it will get a checkout, and if It is still acting up maybe someone there will have an idea.
Al
S/OS #004
Old 12-29-2014, 06:21 AM   #19
1981 31' Excella II
New Market , Alabama
Dragging brakes is not uncommon. Back off the ones that are running hot till they don't run hot. Your hand will tell you which ones are running hot.
Perry
Brakes Grabbing ttbikes Brakes & Brake Controllers 20 06-13-2014 12:06 AM
One out of four grabbing? Chatthayer Brakes & Brake Controllers 7 11-07-2012 06:24 AM
Brakes Grabbing and Noisy Ag'71 Brakes & Brake Controllers 2 09-18-2010 07:56 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
