Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-16-2019, 06:53 AM   #1
Lee-Robert's Avatar
2017 Basecamp
Albuquerque , New Mexico
LED behavior on Curt Spectrum Brake controller
Just had one of these installed. During normal driving conditions; what color LEDs should light up when I apply the brakes?
Should more LEDs appear as I exert more stopping pressure to the brakes?
Right now I only see one red LED light up no matter how much I use the brakes.
Lee-Robert is offline   Reply With Quote
Old 04-30-2019, 08:40 PM   #2
Calgary , Alberta
Hi Lee-robert, Just wondering if you ever found out the issue above? I am running into the same problem
clowrym is offline   Reply With Quote
Old 05-01-2019, 06:52 AM   #3
Lee-Robert's Avatar
2017 Basecamp
Yes. In my case the solution was that when the dealer stuck the control knob on it was rotated such that my vision of the lights was blocked by the knob. What I was seeing was in fact the third red light when I hit the brakes.
According to the support tech at Curt; the number of red lights should increase as more brake power is asserted. The actual number of red lights that appear depends on how you have tuned the controller.
Old 05-01-2019, 08:55 AM   #4
Calgary , Alberta
Thanks for the info, I guess my issue is a little different. I have a single red light as soon as the trailer is connected, that does not change regardless of whether I press the brakes.
Old 05-01-2019, 09:18 AM   #5
Lee-Robert's Avatar
2017 Basecamp
I worked with Brad in Tech Support at Curt. He was very helpful. Hope that you are able to get it sorted out soon.
Old 05-04-2019, 02:28 PM   #6
Calgary , Alberta
It turned out the issue was my vehicle doesnt recognize the controller as it doesnt draw enough power on the brake circuit line. Introduction of some resistance solved my problem
Old 09-15-2020, 07:33 PM   #7
Woodstock , Georgia
Please help!
I have the same issue! How did you add "resistance"?
Ruby on Dubs is offline   Reply With Quote
Touareg and Curt Echo brake controller? lstyles Towing, Tow Vehicles & Hitches 6 08-13-2020 04:20 PM
Fall 2018: The Spectrum of Full-timing Life westcoastas Full-Timing, Winter Living & Workamping 22 11-13-2018 10:13 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
