Old 12-19-2016, 12:09 PM   #1
2019 27' Globetrotter
Salem , Oregon
Lazer Thermometer
Harbor Freight sent me a coupon for a lazer theremometer for $4.99 with coupon. If you want to check your brake temp etc this is a very good deal.
Dave
NoResults is offline   Reply With Quote
Old 12-19-2016, 12:16 PM   #2
ericpeltier's Avatar
Superior , Colorado
I bought one of these years ago. Handy in the kitchen, kid's science projects, garage, bedroom, etc.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 12-19-2016, 01:19 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That's a great price for a neat tool.
Richard
Old 12-19-2016, 03:43 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Part number?
CRH is offline   Reply With Quote
Old 01-19-2017, 10:05 AM   #5
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
Laser thermometers are the absolute best way to determine the optimum tire pressures for any rig. After driving on a good stretch of interstate allowing he tires to get up to temperature, stop and check the inside, outside and center temperatures of your tires.
If you have too much pressure, the center temperature will be higher. If the edges are hotter, you have too little pressure. You'll need to test several pressures and temperatures with the goal of getting the temperatures as close as possible. Finding the optimum pressures will maximize ride and tire longevity.
John Woodrow is offline   Reply With Quote
Old 01-19-2017, 12:02 PM   #6
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Yes. VERY revealing tool to have.
Being in Southern California, few towing trips driving many continuous hours got 95F to 110F tire temps on warmest days 90F was the ambient air temp.
Seems tire temps ran approx 10F higher than ambient or more if facing the sun however 1 front curb tire and hub was consistently 5-10F more than the others. This likley having to do with hotter (tighter) brake pad adjustment on it so more friction comparatively. Probably why it locks up first on gravel !
Love the tool !
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2020 GMC Sierra Denali Diesel 2500 4X4 10 spd 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 01-19-2017, 01:28 PM   #7
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I use one for tires, hubs and brakes but you want to get some stares, pull one out to check the temp of some cast iron over a campfire before you drop that first batch of batter for pancakes. That's cheating. Also works great for most any heat related diagnostics. Engine cooling system for example.
GCinSC2 is offline   Reply With Quote
Clock / Thermometer balrgn Electrical - Systems, Generators, Batteries & Solar 20 08-05-2012 09:46 AM
Thermometer repair, replacement needed bmklawt General Interior Topics 5 10-23-2009 07:25 AM
AAHH! Broken thermometer in waste tank! happydaze Waste Systems, Tanks & Totes 1 04-29-2006 10:59 PM
Who Turned down the Thermometer wingfoot321 Off Topic Forum 0 03-21-2006 10:29 PM
Where is the outside thermometer? InspectorDread Interior Restoration Forum 8 03-07-2005 10:08 AM
