Old 11-05-2009, 07:00 AM   #71
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Originally Posted by 2airishuman View Post
yea but were they painted black?
mine are painted black
cheers
2air'
Dosen't the paint go away after first use and leave bare steel?
Xbob2 is offline   Reply With Quote
Old 11-05-2009, 08:11 AM   #72
_
hi bob
that black paint reference and exchange in posts #13-15 is related to centramatics...
these are aluminum plates with oil bathed bearings at the perimeter...
and provide 'continuous' balancing to the wheel/tire assembly.
they are slipped over the lug studs just before the RIM/wheel are mounted.
here's a pic (zooom it) with 2 centramatics and one rotor just before the plate is put back on...
i had some early concern using them MIGHT limit cooling the rotors and lead to warpage, but that appears to be UNfounded.
the rotors are fine (as are other users), and the balancing plates keep MOST brake dust from reaching the rims.
____________
i guess is u r thinking of painted rotors, which come in SOME of the kits...
and THAT paint would come off with braking.
for more photos of the installation and other user tweaks read here...
http://www.airforums.com/forums/f439...ics-30727.html
cheers
2air'
Old 11-05-2009, 08:40 AM   #73
1962 28' Ambassador
1962 30' Sovereign
hi bob
Attachment 90394
____________
cheers
2air'
Thanks! I was corn-fused
Old 11-05-2009, 11:48 AM   #74
Centramatic balancers.
Centramatic balancers contain anti-magnetic weights suspended in synthetic oil, and are automatically redistributed as the wheel turns.
The beads are durametal, a hardened lead alloy. The dampening fluid, is a proprietary synthetic oil.
Centrifical force places the weights in exactly the correct position. down to 1/10 th of an ounce, which produces a continual dynamic balance.
They increase tire life 25 to 50 percent.
They help prevent tire cupping.
Tires run cooler.
Automatically balances as you drive and/or tow.
Reduces vibration.
Easy and simple to install.
They start working at typically 20 to 22 mph.
They are covered by a 5 year "Unlimited mileage warranty".
That information comes from Centramatic.
Old 11-05-2009, 12:11 PM   #75
_
They.....?
claims are only claims.
this thread is really about disc brakes.
with a couple of corollary notes related to the C product.
but there are MANY threads out there on these pie pans...
http://www.airforums.com/forums/f438...ate-32907.html
going back AT LEAST 5 years...
http://www.airforums.com/forums/f437...ces-10971.html
and on less expensive, also "PROVEN" alternatives...
http://www.airforums.com/forums/f438...eads-4460.html
http://www.airforums.com/forums/f465...nce-28001.html
____________
in USAGE i've experienced NO INCREASE in tire life and NO CHANGE in tire temps.
but the wheels have ALSO been balanced correctly at the bead and on the wheel back side...
so MY personal experience with the pie pan/plates is mixed, after nearly 3 YEARS of use.
VERY easy to mount, keeps the wheels a little cleaner...
but NOT much else in the way of MAJOR improvements as advertised.
i do pretend that they reduced the NEED for rebalancing tire/wheels as the tread wears away,
but that may be JUST MY IMAGINATION (gotta love that song)
also they do NOT fit behind the standard STEEL spare rim supplied by a/s on newer units.
________________
the plates ARE nicely made.
another NICE FEATURE is that SO MANY VENDORS carry them,
AND they can be ordered directly from the maker...
CHOICE (brake options, balancing options, vendors) is a very good thing.
but ALL magic claims should be swallowed in tiny bites and with help nearby in cases of a bad reaction to the magic.
i've read that spam makes a VERY good car wax too...
cheers
2air'
Old 11-05-2009, 12:38 PM   #76
Someday, someone just might make a product that won't be subject to ridicule, or accused of false ads.
Disc brakes are here to stay, regardless, but if someone doen't like them, they can always go back to electric brakes.
Disc vs Drum Brakes? Thrift Brakes & Brake Controllers 39 08-11-2007 12:19 PM
Setup of Actibrake with Kodiak disks on Bambi mswartz Brakes & Brake Controllers 18 02-13-2007 10:31 AM
Kodiak Hydraulic disc brakes thenewkid64 Brakes & Brake Controllers 1 07-06-2004 10:48 PM
Are our axles undersized ? Mike B Axles 5 09-19-2003 06:21 AM
Vacuum disks locking unexpectedly wvmiller Brakes & Brake Controllers 1 04-26-2003 10:12 AM
