Old 04-24-2012, 09:28 AM   #1
Taylormade's Avatar
1978 31' Sovereign
Just wanted to confirm 12/2 for a '78 Sovereign?
I'm looking to replace my backing plates and wanted to ensure I got the right ones. This is what I'm checking out.
Any help/feedback would be greatly appreciated. Thanks!
Scott
Taylormade is offline   Reply With Quote
Old 04-24-2012, 10:07 AM   #2
Scott
Those are OK.
Old 04-24-2012, 10:40 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There is a different part number for the other side of the trailer.
Richard
Old 04-24-2012, 10:52 AM   #4
Taylormade's Avatar
1978 31' Sovereign
Originally Posted by Inland RV Center, In View Post
Those are OK.
Thanks Andy, when you say "ok", do you mean there's a better option for me or those will work just fine?
Yep, just need two per side, right? Nothing else I'm missing?
Old 04-24-2012, 10:55 AM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
Since you are replacing thew backing plates, it would be a good time to repack the wheel bearings. I would add 4 grease seals and some grease to the list.
Richard
Old 04-24-2012, 12:10 PM   #6
Taylormade's Avatar
1978 31' Sovereign
Yeah, actually the PO must have just had that done. That's how I found out I needed hardware kits for the brakes. The bearings and grease are new within 3 months.
Thanks!
Old 04-25-2012, 09:55 AM   #7
Keep in mind, that the brake rating is only true when "everything" in the brake system, is perfectly adjusted.
You are looking at 5200 pound backing plates.
There are 6000 pound backing plates that are also available.
Then to go one step even better, you can get 6000 pound brake assemblies, "that are self adjusting". Those keep the brake system as close to perfect adjustment all the time, as you can get.
sovereign
