Old 08-13-2008, 04:09 PM   #1
1966 26' Overlander
Conover , Ohio
just springs
I am overhauling a 66 Overlander. The brake shoes, magnets and drums are fine, it's just that most of the springs are broken. Any chance at finding a spring kit? I think it is the Hayes brake system. Any help would be appreciated. Thanks, Tom
air66stream is offline   Reply With Quote
Old 08-13-2008, 04:15 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It should be 12" brakes on your trailer. Just go to almost any trailer repair shop, and pick them up. They are standard springs that have been used for decades on almost every trailer with electric brakes. They are not Airstream-specific.
Now, if they are really old brakes, I would strongly recommend replacing them with loaded backing plates. They will come with shoes, springs, magnets, and adjusters, and are pretty much bolt-on. SHoes don't last forever, no matter how thick the friction material is. Eventually the epoxy that holds the friction material to the table will fail, and most likely will cause the brakes on that wheel to lock.
Old 08-13-2008, 06:20 PM   #3
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I carry an extra set I got from Federated auto parts but I know NAPA also carries just about everything for them. In a pinch you probably could get away with an old 10 bolt chevy kit and pilfer springs to get you to a repaire shop or campground or home. I agree with the loaded back plates, I learned the hard way on that issue
mustang is offline   Reply With Quote
Old 08-13-2008, 06:46 PM   #4
Alumanutz's Avatar
1966 22' Safari
Chico , California
I'm not sure how much of a hurry you are in but I am in the process of installing a new dexter axle on my 66 Safari. I could send you the old springs if you like. I wouldn't think this would be a long term fix but that is up to you to decide.
NUTZ
Alumanutz is offline   Reply With Quote
Which springs do I need? richnritab Axles 6 09-26-2006 06:57 AM
Seven Springs Penn. gypsyfox On The Road... 2 04-15-2006 01:26 PM
Springs Ken J Axles 6 06-30-2004 06:07 PM
Too many Springs, So little time Towhead On The Road... 7 06-22-2004 08:22 AM
leveler springs kooblekidz Airstream Motorhome Forums 3 02-10-2004 05:43 AM
