Old 02-23-2011, 01:56 PM   #1
1985 29' Sovereign
Winter Park , Florida
Just bought 1990 excella brake question
Just purchased 1990 excella, so far have pulled two of the three road side drums and measured the depth of brake pads (to the top of the rivet) with a tire tread depth guage and just a hair less than 2/32 left, pretty even across all rivets. Is it time to replace these brakes or can I run them a while?
safariuser is offline   Reply With Quote
Old 02-23-2011, 02:15 PM   #2
Since the brakes are 20 years old, I would replace them.
You only have maye a couple of thousands of miles left on the originals, anyway.
You can now purchase electric brakes, that are self adjusting.
Simply replace the complete backing plate, which costs just a little more that the shoes, but probably around the next corner, you would need the magnets too.
Magnets and shoes cost more than a complete backing plate.
Old 02-23-2011, 03:30 PM   #3
1985 29' Sovereign
Andy: I'm correct in assuming these are likely the original shoes? Are you basing that on the rivets? If you look at the level of rust elsewhere around the axle, break mounting flange, within the brake mechanism itself, it all looks about the same to me. The reason I ask is the man I bought this from only put less than a thousand miles on it in the two years he owned it and he said the previous owner had inherited it from his father. I'm just trying to get an idea of the total mileage. What do you think?
1990 excella, brakes
Just bought a 1977 28ft Argosy- Need Your Expert Advice GarrettRing All Argosy Trailers 18 05-15-2011 05:58 AM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
1990 32 Ft Airstream Excella eBay Watch Airstreams on eBay 0 01-15-2011 09:50 AM
