Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-12-2006, 11:30 PM   #1
kramynot2000
kramynot2000's Avatar
Profile:  1978 31' Sovereign
Sacramento , California
Images: 20
Just Bought 1978 31' with hydraulic brakes, how do I get it home?
I just purchased a very nice 1978 31' International. I have a Nissan Titan all wired up with hitch and noticed that the Airstream has a hydraulic disc brake system, which I've never seen before. I've read on this forum about converting to systems such as actibrake, which I will do. But for now, how do I get this home? If I just hook up the 7 pin wiring harness, will the brakes work at all? Any quick fix so I can tow this home.
I'll be towing about 150 miles but there is a sharp downgrade (6% I think) which I'm a little worried about.
kramynot2000 is offline   Reply With Quote
Old 08-13-2006, 02:25 AM   #2
dufferin
dufferin's Avatar
Profile:  2007 28' International CCD
on the go , Canada
Images: 11
It's suppose to work the same...
In case you want really to bee sure hooked up your AS and try, with a strong set up, you will notice pretty fast if it works... you'll feel that the car is being "grabed" by something..
Pdt Canadian Atlantic U. - WBCCI # 6162 - AIR #8059
Attn : IBT
Here's what the free of speech is :
"I may not agree with your ideas but I will fight to death to let you express them"
Voltaire - (rough translation from french)
dufferin is offline   Reply With Quote
Old 08-13-2006, 04:59 AM   #3
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
If it is the original hydraulic system, you need a vacuum line from the TV to the trailer. Without it, no brakes.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 08-13-2006, 09:06 AM   #4
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
The vacuum source can be taken off manifold vacuum from your engine. Find a full time manifold vacuum port (usually a plug in the manifold, make sure it is not a water port) get a male brass fitting and fit a brass barb. Hook up about a foot of airbrake hose and put in a check valve. On the other side of the check valve (screw in brass barbs both side of valve to hook up to hose) attach the length of airbrake hose you will need to get to your back bumper. You can thread the hose through and alongside your truck frame. At the bumper, attach a barb and a 1/2" female industrial quick coupling which will allow you to connect the male coupling from your trailer. You may have to remove the male coupling from the trailer tongue hose and replace it with a male coupling that mates with the female coupling you mount under your bumper. This should give you the vacuum you need for the booster on the tongue. You might also remove the cover over the brake booster unit on the trailer and check it for proper fluid level just like you do on older cars. As soon as you plug the unit up you should hear hissing which will stop in a few seconds. If not, you might have a leak in one of the hoses or the booster diaphram.
If you do a forum search or check my posts regarding the Hydravac unit you will see some of the pictures I posted of how I set up my system.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-13-2006, 11:28 AM   #5
Holzarbeiter
Profile:  1978 31' Excella 500
Goose Creek , South Carolina
I converted my hydra/vac to the dexter unit, this was a quick and painless conversion. When I brought my unit home I opted to go without brakes since the old system had not been used in some time and it would have taken days to get parts or rebuild parts to get the system working. I would ask the PO when the system got used the last time. If you or he has the service manual, read up on the system and perform the necessary checks. If you opt to pull home without brakes put the TV in a lower gear to help slowing you down on steep grades.
Congrats on your new purchase and read up on Davidz71. He got his system working and seems happy with it.
Holzarbeiter is offline   Reply With Quote
Old 08-13-2006, 11:51 AM   #6
Coastalview
Coastalview's Avatar
Profile:  1978 29' Ambassador
Carmel , California
I'd listen to the advice that Craig has listed. You may find that this setup will work fine permanently, if the trailer hydravac-brake system is working properly. You indicated a 6% grade between you and the current location of the trailer. My best guess is you would be pulling the trailer west on I-80, which has some long 6% grades. If this is the case, be prepared to replace the brakes on the Nissan when you get home, if you survive the trip. I have an independent vacuum source mounted in our trailer with the same brakes, due to our tow rig being a diesel. This set up could be done on a temporary basis. (we have run it this way for 4 years, but some feel not DOT. compliant) Send me a PM or an e-mail, and I'll explain with photos. Jeff
78 Airstream Ambassador 29'
97 Ford Powerstroke 4x4 Crewcab Shorty
AIR# 649
Coastalview is offline   Reply With Quote
Old 08-13-2006, 07:56 PM   #7
kramynot2000
Images: 20
Sent you PM and email.... I think
Coastalview,
Sent you a PM and email. Hopefully it worked!
Tony
Tony and Gale
1978 31' Sovereign International
Old 08-13-2006, 09:43 PM   #8
ZoomZoom
Profile:  1960 24' Tradewind
Riverside , California
There is about a 6-8 gallon vacuum storage reservior under the front floor, so if you can rig some sort of a 12v vacuum pump you'll have some sort of braking. The system operates with the same brake controller as electrics but uses less current, only enough to open the sync valve.
ZoomZoom
ZoomZoom is offline   Reply With Quote
Old 08-14-2006, 08:36 PM   #9
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Kramy,
I agree with Zoom Zoom. I'd rig up a temporary vacuum source; some kind of reservoir with a 12v pump. I'd test it before I moved the trailer.
I towed my 31' home with no brakes of any kind, through the mountains of WV, which were easily 6% as well, but probably not as long as you'll encounter. I only went about 40 miles, and I had a much larger, longer, and heavier tow vehicle than your Titan.
If you can't get the old brakes to work with a temporary vacuum system, you might consider just renting a larger tow vehicle and bringing it home with no brakes. Get a U-Haul 26 foot box truck or something similar. Super long wheelbase, dualie, and heavy. Just take it easy.
- Jim
JimGolden is offline   Reply With Quote
Old 08-14-2006, 08:46 PM   #10
kramynot2000
Images: 20
Thanks guys
I am trying to rig something to get a vacuum and Coastalview is giving me a hand.
Good idea though about renting a bigger TV if I need too. I've also rechecked my route and found one path that will avoid all significant downgrades.
Tony and Gale
Old 08-15-2006, 07:07 PM   #11
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Just go slow. Take a weekend day that the traffice will be less and take it easy.
>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Home Page Photos 1985air345 Forum How-To's & Support 1 09-09-2002 04:20 PM
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 6 08-26-2002 10:20 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 06:02 PM
