Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-24-2004, 08:15 PM   #1
57overlander
Profile:
jordan 2020 brake controller
anyone have an opinion on this "cable" driven unit that attaches to the brake pedal bar itself, and increases the amp in direct porportion to the amount of travel on the brake pedal?
I see some advantages, but don't know anyone who has used it.
Kleven Enterprise, LLC
PO Box 715
Daleville, AL 36322
SALES - Toll Free (888) 828-1893
info@BestBrakeController.com
Authorized Jordan Research Corp.
Distributor and Dealer
57overlander is offline   Reply With Quote
Old 11-24-2004, 08:53 PM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
I've got a Jordan unit and love it. I think it works much better than the Tekonsha Voyager it replaced. I use it on the Airstream, a 10,000 GVW flatbed equipment trailer and a horse trailer. I love it.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 11-25-2004, 07:40 AM   #3
ctdair
ctdair's Avatar
Profile:
For what it's worth I had considered one , every reply anyone had about jordan has been positive. However I decided to go with the brake smart controler which does the braking based off of pressure from a transducer t'eed into the brake line. same with it all replies in research wher positive. Mine has been on a week and wont be towing for another 2 weeks for first report.
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2002 Dodge Diesel 4x4 Dually
ctdair is offline   Reply With Quote
Old 11-25-2004, 12:23 PM   #4
markjoandall
markjoandall's Avatar
Profile:  2001 30' Excella
Bedford , New Hampshire
I've used the Jordan for the last two years. Before that we used the tedonsha. I think the Jordan matches my braking more closely than the prior one. We have probably put about 15,000 miles on the trailer with the Jordan.
Try it your'll like it.
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 11-25-2004, 08:02 PM   #5
uncleneal
uncleneal's Avatar
Profile:
One advantage of the Ultima is that it is half the price of the Brakesmart.
Just unhook the cable when you're not towing like they say in the instructions. Between that and corroded cable plugs, mine fried the big transistor inside. They fixed it for less than $30.
I'm still very happy with it. A whole lot better than the Techonsha I borrowed while it was being fixed. It's easy to adjust between loaded and empty when I pull the flatbed or the AS, and you just set it for the weight and leave it.
Neal
uncleneal is offline   Reply With Quote
Old 11-25-2004, 08:10 PM   #6
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
The Jordan is O.K. & has real advantages over most others. I put the Brakesmart in mid-summer & wonder why I didn't do it sooner. So what if it cost a little more, this unit WORKS. True proportional braking, no adjusting for hwy, cty, backing, etc. Just press the cal. sw. after hook-up & drive!! Nothing like it except the new optional $400+ Ford controller which uses the same technology.
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Jordan Research Ultima Brake Controller RoadKingMoe On The Road... 0 09-26-2002 01:41 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 09:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 01:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 11:11 AM
