Old 07-13-2008, 10:18 AM   #1
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Jake Brake
Our Land Yacht diesel pusher has the "Extarder" by Jacobsen, also
known as the "Jake Brake".
In our unit it quit working and my investigation finds power after the switch but not at the activator lever at the exhaust.
Question: Is there a circut breaker or relay somewhere between the dash
and the engine? If so where?
Any help is appreciated.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 07-13-2008, 11:33 AM   #2
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
There should be a switch on the accelerator pedal or linkage, most likely a micro-switch. Make sure there is power to the switch and then through the switch when the accelerator is in the idle position. If not the switch needs adjusted or replaced.
Godspeed,
Trent
blacksheep is offline   Reply With Quote
Old 07-14-2008, 07:47 PM   #3
Trent,
Thanks for the reply. I found the switch at the rear end of the accelerator cable. But no power to it.
I ran a jumper and that switch works when it gets electric.
I checked the Jake brake and it works with a jumper.
Problem is that the switch on the dash is hot on the out side, but not at the rear micro swtich.
I traced it from the dsah switch and it splts with one wire going in to the Allison shifer module. From there the wire going to the rear is dead.
Because I just spent $2700 getting that replaced, I'll take it back to Allison. That's to much money to risk self repairs.
Thanks for the help.
Paul
Paul
Old 07-14-2008, 08:01 PM   #4
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Paul,
Didn't think to ask if it was tied into the Allison. Could be as simple as re-programing if it is computer controlled. Yeah, I would take it back to them too. If it worked before they got hold of it they really need to fix this issue at no cost.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
Old 07-15-2008, 04:33 PM   #5
Jake Brake failure tied to Allison ECU
Well gang, after spending a day checking and rechecing, ?I was able to hot wire the Jake Brake and everything worked. The Allison ECU was wrong and had no program for the brakes.
It's in the Allison shop now and I hope no charge.
Thanks to all who responded.
Paul
need brake help crowbar68 Brakes & Brake Controllers 12 06-24-2008 08:51 PM
Brake controller? chaunceyboy Brakes & Brake Controllers 7 06-07-2007 10:43 PM
I need a brake Over59 Repairing/Replacing Floor &/or Frame 7 12-07-2004 04:00 PM
Brake Wiring airhead Brakes & Brake Controllers 8 08-19-2004 11:54 AM
6V Brake ? Deluxe21 Brakes & Brake Controllers 8 08-25-2003 02:42 PM
