Old 05-24-2011, 06:04 PM   #1
Plainfield , New Hampshire
ITBC on 2011 Silverado locks up AS brakes
I have a 73 Overlander 27ft. I just got a Silverado 2500 HD LTZ "with everything" including an Integrated Trailer Brake Controller that gets set by the computer on the dash, e.g., it will say brake delay 5. But when I hook up the AS, all the lights work correctly, but the brakes come on and stay on and the dash board readout goes to 0. Does it need a fuse? What's with it coming with a dummy fuse? Does it need a ground? Anyone with similar experience or solutions?
MikeAir is offline   Reply With Quote
Old 05-24-2011, 06:12 PM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
1st question that comes to mind is which brakes does your Airstream have? Electric magnets or electric over hydraulic ?
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-24-2011, 06:18 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down
If so you may have to go with a TruControl or P3 type controller.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 05-28-2011, 10:54 AM   #4
JFScheck's Avatar
Rockville , Maryland
Images: 33
Remember - you can only support Electric brakes with your GM brand Brake Controller vice the Ford & Ram trucks.
If you do have Electric brakes, then I would next check for shorts in the wiring, sounds like when the voltage is applied the brakes are engaging - also, check the magnets in the drum brake assembly for shorts...
Good Luck - get her on the road!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-28-2011, 11:15 AM   #5
richinny's Avatar
2011 34' Classic
check to see if the trailer is wired to current configuration standards.
this thread might help:
http://www.airforums.com/forums/f37/...tor-52864.html
Ricky
Old 05-28-2011, 12:02 PM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Our 2008 Silverado LTZ with the dash controller operates perfectly when pulling our 1999 Excella. So you know, at least, that one configuration works without modification.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 08-04-2011, 06:04 AM   #7
2011 31' Classic
Images: 8
Hmm . . . Never heard the end of this current story, but OUR situation has changed in the past two weeks. Now our integrated controller will not lock up the brakes at even the highest setting of 10 on the gain. In the past I could lock up at between 6-8, and we generally travelled for over 10,000 miles set a 8.5 with nice control. Manually applying the trailer brake now SLOWS sum but will not stop us.
QUESTION: What should I check first, second, third . . .?
Old 08-04-2011, 06:14 AM   #8
I would check gain at the controller...trailer connector...magnet's.
Sounds like a wiring concern.
PFC
"Tahawus"
RLC
John Prine
chevy, fuse, ground
Prodigy P3 Wiring - 2011 Silverado Ganglin Brakes & Brake Controllers 0 04-17-2011 09:46 PM
