Old 09-18-2009, 05:04 PM   #15
Pappy's Avatar
2006 25' Classic
Floyds Knobs , Indiana
Rich, I guess I will find out I ordered the Dexter today. I do see that it takes 3 volts to activate the system. That has me scratching my head a little since the way my Prodigy works now it very rarily gets above 3 unless I use the manual lever which is never other than testing. I thought the numbers on the prodigy were amperage but according to the manual its voltage. I have it on boost 1, I may have to put it on boost 2 to get a little more initial voltage. What brake controller are you using?
If its not running at the stops I wonder at what point does the trailer stop braking vs the Truck holding it back. As you see I am already having Desi & Lucy night mares.
Pappy
Pappy is offline   Reply With Quote
Old 09-21-2009, 11:16 AM   #16
hookedonclassic's Avatar
Fond du Lac , Wisconsin
I am posting a couple more pictures of the Dexter installation. The pictures show how the oil lines are connected going through the A-Frame box which had adequate room. However, the electrical connections (curbside) are a very tight fit from the looks of it. I had the dealer do the install so I didn't experience it first hand but I know that it took 4 hours for them to do it. Hope this helps in the event others change from the Actibrake to Dexter pumps.
Name:	IMG_5379 (Medium).JPG
ID:	87497   Click image for larger version
Name:	IMG_5381 (Medium).JPG
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 12-20-2010, 08:14 PM   #17
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Email sent to Colin....
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 04-03-2011, 09:03 AM   #18
Flying Gypsies's Avatar
2006 31' Classic
Archer , Florida
Just picked up new-2-us 2006 classic 31 in Pa and went 1500 miles flawlessly- stopped at a campground in SC and when we pulled away the actibrake stopped worling- thanks to this thread, we were able to "re-boot" and get back on the road- hoping 2 make last 250 miles- will be looking into a new actuator. THANK YOU so much for all of the Airstreamers support in this forum.
Flying Gypsies is offline   Reply With Quote
Atwood Gas water heater - 'click then shuts off'???? kevinyyz Water Heaters, Filters & Pumps 3 05-11-2009 10:18 AM
Shurflow fan shuts down thehiker Roof Vents, Skylights & Fans 2 10-17-2008 04:54 PM
ActiBrake Silverslug Brakes & Brake Controllers 4 08-23-2008 11:54 AM
Issue with 110V system... redynvre General Motorhome Topics 12 01-20-2005 10:48 AM
Electical Issue - 12 Volt System.... Craig Electrical - Systems, Generators, Batteries & Solar 9 10-13-2004 10:47 AM
