Old 09-28-2010, 12:22 PM   #15
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
The latest news is I went back to the original owner of the truck and he surpirised me by handing me the brake box along with the seven pin plug/ mount. Then I went to a friends garage and he said he will put the truck up on a rack and will trace all the original wires and will re- install what the owner gave me. This is going to cost me 100.00. Can't beat that huh?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 09-28-2010, 05:59 PM   #16
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I love a happy ending. Congrats to your research and perseverance.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 10-01-2010, 07:13 PM   #17
1970 27' Overlander
Today I went and bought what looks like a lesser quality seven pin plug to replace the old one. It was tricky moving the wires to the new location. So thats one more fix. Here's a picture of the old one I used just in case I forgot the color sequence. But I made it alright with out the picture.
I have also included a shot of the door sticker that shows the stats of the truck itself.
Can you tell me what it means? Like the weight and the axle size?
Thanks, I really need to be educated with this.
ID:	112108   Click image for larger version
Old 10-01-2010, 09:02 PM   #18
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Rear axle size is a 8.8 inch. The gear ratio is on a tag on the rear axle. If you are under the truck between the rear axle and bumper looking forward the tag is on the right hand side of the gear cover. It will have a 3.55 or 4.10 or 3.73 something like that . That number is the gear ratio. Quite likely the first diget will be obscured by the bolt holding the tag to the axle housing. If that is the case you will see a .55 or a .10 or a .73. Also if the axle is a locker there will be an L, as in 3L.55 or 4L.10. Rear GAWR is the rear axle rating, yours is 3166 lbs. GVWR is the rating of the entire truck, yours is 5450 lbs. Adios, John
Diesel1 is offline   Reply With Quote
Old 10-01-2010, 09:45 PM   #19
1989 32' Excella
Limestone , Alabama
Below is a link to help you decode your vehicle door jamb sticker - your axle code = 19, looks to have been built with a 3.55 ratio non-LS (not limited slip).
Vehicle Door Jamb Sticker Decoding Page
Lots of good Ford truck forums out there to help you learn about your truck.
You've already found the best Airstream forum!
Best wishes and enjoy the journey!
Steve
war eagle is offline   Reply With Quote
Old 10-02-2010, 07:02 AM   #20
1970 27' Overlander
I had applied to a 'pick-up forum, where I posted something the same like I did here, Thanks, The internet is so vast and deep. I book marked to that and will be looking into it after I return from work. study study study!
Old 10-02-2010, 07:31 AM   #21
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
When it turned out that our '01 Dodge truck didn't have trailer wiring at all, I bought a prefab harness from the dealer and installed it myself. Lotsa crawling under the truck, but not a bad job.
The controller wiring also wasn't pre-installed in the truck, so after many conversations with a dealer who said I just wasn't looking in the right place, I Googled "Brake Controller Install" and got some great instructions. It's been more than two years, so I don't remember exactly where I found them.
A four-pin trailer plug only runs the lights, so make sure you have wires under the truck for the seven-pin setup.
Old 10-03-2010, 11:58 AM   #22
1970 27' Overlander
Will do!
Installing Marmoleum Lumatic Floor Finishes 10 08-19-2009 01:04 PM
Price Paid to Price Asked BillWill Trailer Values 46 08-11-2009 05:03 PM
Installing an awning... AIR-Quarius Awnings 4 02-17-2009 05:24 AM
PLEASE HELP.. installing new tanks Brunonb75 Waste Systems, Tanks & Totes 8 07-23-2007 06:58 AM
Installing carpet M&J Siegford Repairing/Replacing Floor &/or Frame 13 04-17-2004 01:55 PM
