Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-24-2009, 05:19 PM   #1
Profile:  1963 19' Globetrotter
Moline , Illinois
Intermittent brake loss problem solved
On my last couple of trips, My Prodigy brake controller would display no connection, especially when on rough road. I suspected a ground problem or a loose connection in the wiring and was prepared a lengthy search. I could not believe what it turned out to be. Some how , the connection from the controller (a harness from Prodigy) into my factory harness (Dodge 2500) had come loose. I couldn't believe as it has been in the truck for four years with no problem and I don't see how this thing could come apart . Thirty seconds of time to snap it back together and the problem is fixed.
63air is online now   Reply With Quote
Old 07-24-2009, 05:48 PM   #2
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
So, how long did it take you to figure it out? I hate it when that happens.
Pay no attention to the man behind the curtain- WoZ
Lumatic is online now   Reply With Quote
Old 07-27-2009, 10:32 PM   #3
Moline , Illinois
About 15 minutes. Figured I would look for loose connection at the brakes, then checked the umbilical and cleaned the connections, then I looked at the controller connections and gave them the old shake test. It just fell apart.
Intermittent brake lockup gnored Brakes & Brake Controllers 27 03-20-2009 10:25 AM
Intermittent 12v elec problem & solution ole81 General Interior Topics 4 07-29-2007 11:01 AM
one problem solved..now need to find new burner! JohnGalt48 Water Heaters, Filters & Pumps 8 06-24-2007 03:48 PM
Fridge problem solved Don in E Texas Refrigerators 3 10-14-2005 01:48 PM
Fuel problem solved George Mechanics Corner - Engines, Transmission & More... 0 09-06-2004 07:25 AM
