Old 01-07-2009, 07:48 PM   #29
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
1) My Actibrake instructions call for #10 wire. 30 amps required.
2) All the connections need to be really solid and tight. I understand micro ohms of resistance will upset the Actibrake.
3) Brakeaway hot wire goes to the hot side of the A/S batteries. I did mine at the fuse box which is in the front center of the A/S, close to the Actibrake.
4) Be sure to unplug the umbilical first, then the breakaway. Just like if your truck leaves with out the A/S, the brakeaway cable pulls after the truck leaves. Hitching up, plug in the breakaway first, then do the umbilical. Book says it really upsets the Actibrake if you pull the breakaway with the umbilical plugged in. When I pull the pin on the breakaway cable to loop it through the bumper, I have an automatic test on the system, the Actibrake does its noise while I'm plugging it back in. Also works to use it for bleeding the brakes by yourself.
5) It's a great feeling to be pulling down your speed of the A/S and the truck, even full stop by pushing the manual switch on the controller of your disc brakes on the steep. You KNOW the trailer brakes are working.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-22-2009, 05:11 PM   #30
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Staring the axle disc barke install today
Couple of questions. The wiring harness connection for the Actibrake actuator has alignment slots and a 1/4" set screw to attach to the back of the actuator. I am correct that the connection can not simply be pushed in all the way without tightening the 1/4" set screw.
Also the brake line kit came with a small brass male/female connection that looks like it would be used at the bake line connection at the actuator. Am I correct that this is not needed with the Actibrake since it appears that the connection is the same size on the actuator as the bake line.
adonh is offline   Reply With Quote
Old 01-25-2009, 08:50 AM   #31
adonh's Avatar
1976 31' Sovereign
Help-Wiring the actibrake actuator
This morning we are connecting the 5 wires from the Actibrake. Trying to sort out the connection points in the 76 Airstream and converting the wire colors used at that time Blue 12 v yellow brakes. does anyone have a description of where you connected the wires coming from the actibrake.
Old 01-25-2009, 05:10 PM   #32
adonh's Avatar
1976 31' Sovereign
Actuator connected
After going over the wiring digram and Actibrake instructions and the service manual for my 1976 A/S we finally came to a conclusion on the connections points from the actuator to the trailer. The 76 A/S still has the old standard wiring position and wire colors before the universial 7 pin standard came about. So we had to mach up the correct color and psoition from the old standard. Although the 76 service manaul helped a lot, some of the wire colors after the old seven pin connection cahged which was not noted in the sevice manyal. But after all connection were made and the trailer disconected from the TV, pulled break away pin and the actiabrake pump started and we were able to bleed the brakes lines. Refilled the actuator we new brake fluid. All connections tight no leaks. By this time it was 5:45PM and the sun going down. Will mount the wheels tomorrow, check out the new P3 break controler and try a test drive. For now its "Jim Beam" time.
Don
Old 01-27-2009, 04:52 PM   #33
Sunset Coast's Avatar
2008 31' Classic
Benton Harbor , Michigan
Congrats!
Don, sounds like good success. The wiring colors takes patience to sort it all out, but sure sounds like you got it. "Toast one for me". Looking forward to hearing how the test run goes.
Doug
Sunset Coast is offline   Reply With Quote
Old 01-27-2009, 05:53 PM   #34
adonh's Avatar
1976 31' Sovereign
Thumbs up Kodiak Disc Brake installed with pictures
I posted the information below on the Axle forum section and I want to bring everything current on my thread hear on the brake forum section as well.
The Kodiak disk brake are great. Wow what a difference.
The axle and disc bake job is complete on my 1976 31' Sovereign. The entire process from removing the old axles to the first test drive took 3 days. Removing the old axles and installing the new ones only took about 3 hours. Had a couple of bolts that were really hard to remove but they finally broke free. The main tools needed that I had to gather up ahead of time are a couple of bottle jacks, a floor jack, jack stands, air wrench/compressor, furniture dollies (rented from U-haul), assorted box end wrenches/sockets and a 1/2" 18' socket breaker bar came in handy on those tough bolts. If anyone within driving distance to the Houston area is planning an axle replacement don't go out and buy this things, you can borrow them from me. Just come pick them up and bring them back.
The new Henschen axles fit right in the same spot that the old ones came out of and bolted right in. It does not get any easier than this. Once the bolts are out the old axles are lowered with the floor jack. The new ones are lifted in place with the floor jack as well. Put in the new bolts and you are done. The old axles were shot. The torsion arm was frozen in the level position on both axles. No drop at all when I jacked up the trailer and in this condition you can see how rough the ride was. In the end, the height of my trailer increased almost 3" with the new axles.
The time consuming part was installing the disc brakes, running the brake lines, installing and wiring the actuator. Once all of that was done the final steps were to bleed the brakes and reinstall the wheels, plus install the new P-3 brake controller.
No real problems in the entire process with 2 helpers . The main concern was wiring the actuator back through the connection box at the inside of the trailer. This looked like a birds nest with many different colored wires. Plus working with 3 sets of wiring colors and standards you have to make sure the right wire is connected to the right point. The instructions from Actibrake references their 5 wires connecting to color coded wires in the current universal 7 way connector standard. But the standard was different back in 1976 so the position of the wires, purpose and color was different. Since you can't go by colors you need to trace the actual wire to the right source. I am glad I have the 1976 service manual that had good illustrations on the connections. In the end the right connections were made and the actuator powered on when the break away pin was pulled. After installing the P-3 controller it also checked out as well
The 1st test drive was great. I adjusted the new P-3 brake controller at and empty parking lot down the street from me based on the instructions that came with the unit. Everything checked out so I took off over some city streets and high ways with various road conditions and stops and turns. The first thing I noticed was the braking with the disc brakes. Unbelievable response, smooth as silk. The ride was also very noticeably better. No hard bouncing up and down from riding on the old locked axles. I left a plastic box sitting on the kitchen counter and it was still there after the drive. I am very pleased with the Henschen axles and Kodiak disc brakes. Thanks everyone for your responses and help during the project. Also for thanks to Andy and Greg at Inland RV for helping with my order and answering all of my questions. Great service.
Rather than post individual pictures I have attached a pdf file with install pictures. I can post any individual pictures if needed.
Don
1976 31' Sovereign new Henschen Axles and Kodiak disc brakes
Old 01-28-2009, 07:04 PM   #35
2008 31' Classic
Great job !
Thanks Don for posting your pictures and experience .... you added to the "knowledge base". Time to celebrate ...
Doug
Old 01-28-2009, 08:46 PM   #36
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
Thanks for all of your narrative and progressive photos of your axle and brake replacement. I have been considering disk brakes for our 2005 and this helps in understanding what is required. I'll keep a copy of this if I need further info from you on your experiences. Well done!
wolverine is offline   Reply With Quote
Old 01-29-2009, 12:38 PM   #37
adonh's Avatar
1976 31' Sovereign
Question
After the busy weekend installing the axles and disc brakes I only had time for a short test run on Tuesday before taking the trailer back to storage. Everything appears to be fine and I am looking forward to bringing the trailer home again this weekend. I need to finish up some loose ends on some remodeling that I am doing in the kitchen area and get everything back together before I leave for the Vintage Airstream rally in San Antonio starting next Wednesday. I will also do a longer test run as I bring the trailer home on Friday afternoon.
I read that you should bleed the brakes again after the 1st 100 miles. I plan on doing that before I leave for the Vintage rally. Are there any other "break in" steps that need to done with the new Kodiak brakes before I start out on an extended trip.
Don
Old 01-29-2009, 01:18 PM   #38
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Before you leave on the trip give the lug nuts a check just to be sure. And you might recheck tire pressue.
Otherwise there is no break in for axle assemblies or disc brake lining.
>>>>>>>>>>>Action
Old 02-09-2009, 07:34 AM   #39
adonh's Avatar
1976 31' Sovereign
follow up
The Kodiak disk brakes are working great. We just got back from the Texas Vintage Airstream Rally in San Antonio. The difference from the electric brakes was noticeable. Very smooth proportional stopping at slow and higher speeds. One question One the Actibrake actuator. When you apply the brakes you can hear the pump come on from several feet away. Is this normal
Don
Old 02-09-2009, 08:23 AM   #40
Don
Yes and no. Depends on where you mounted the actuator.
We suggest that it should be mounted inside the trailer.
You won't hear the noise.
The weather can't get to it.
A thief can't see it to steal.
Old 02-09-2009, 08:54 AM   #41
adonh's Avatar
1976 31' Sovereign
Yes it is mounted inside in the small cabinet drivers side just in front of the frig.
Don
Old 02-09-2009, 08:58 AM   #42
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
ours is very loud.. (its mounted in the 'A' frame compartment) that is, only time we don't hear it is at highway speeds.. this is normal
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Installing Disc Brakes - Question Sunset Coast Brakes & Brake Controllers 21 07-17-2007 07:27 PM
Disc brakes. Inland RV Center, In Brakes & Brake Controllers 23 06-28-2005 06:37 AM
Kodiak Hydraulic disc brakes thenewkid64 Brakes & Brake Controllers 1 07-06-2004 10:48 PM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
