Old 04-11-2007, 07:56 PM   #1
Sunset Coast's Avatar
2008 31' Classic
Benton Harbor , Michigan
Installing Disc Brakes - Question
I have received my disc brake kit (thanks Andy!) and I can almost tolerate the cold weather (4" of snow in April?), so I have started the process of installing the system. I wanted to route the brake lines on the back side of the frame but the two tanks are in the way to get in there and work. What do you all think of running the brake line attached to the vertical walls of the tank covers? This would avoid installing the lines in the wheel well area. How much clearance is there between the wall of the tank cover and the actual tank ... is there enough for a rivet? I think I should use a rivet rather than the pointed screw.
"Tanks" for your help,
Doug
Name:	Wheel Well 005.jpg
ID:	35489   Click image for larger version
Name:	Wheel Well 006.jpg
Name:	Wheel Well 004.jpg
Sunset Coast is offline   Reply With Quote
Old 04-11-2007, 08:02 PM   #2
_
Originally Posted by Sunset Coast
What do you all think of running the brake line attached to the vertical walls of the tank covers? Doug
hi doug
i think that is a very bad idea.
frame members, belly wrap, axle mounting steel...
good choices all.
cheers
2air'
Old 04-11-2007, 08:54 PM   #3
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I'm no expert by any means but it appears the arm that goes from the axle to the wheel is level with the ground. If so doesn't that mean your axles are shot?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-11-2007, 08:59 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I would be changing the axles also, as soon as a load is applied your axles will be going in the wrong direction. Sorry you need to get a few more grand involved. Mine had the similar look to them. DG
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 04-12-2007, 11:15 AM   #5
Doug
If you use a rivet, make sure it's stainless steel.
Doug, the bad news is your axles are shot.
The torsion arm, withou load should be about 20 degrees or more downward.
Yours are almost parallel to the groung or chassis, with no load.
Don't waste your time installing the discs on the axles that you have.
Old 04-12-2007, 11:25 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Doug, Andy can get axles for you, then you can have the whole enchilada, and not have to worry about them for another 20 years or so.
Old 04-12-2007, 08:03 PM   #7
2008 31' Classic
Axle angle
I still had the wheels on the other side ... would that affect the "tilt" or lack of tilt of the axle arm?
Old 04-12-2007, 09:57 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, No. They are all independent.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 04-13-2007, 09:51 AM   #9
When the trailer is sitting on its wheels what is the angle of the "arm?" I can't tell from that picture if the arm is on a jack stand. If not it doesn't look good.
According to Andy if its less than 20 degrees you have a worn out axle. Yeah it's a pain in the pocket and the neck.
The other side of that coin is first the new axle will last for a couple of decades and your trailer will not beat itself apart as you really have no suspension with a shot axle. My opinion is that an axle or two is cheaper than the damage caused by no suspension.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 04-13-2007, 04:42 PM   #10
2008 31' Classic
OK - New Axles it is
I really appreciate all the information and insight... that's the incredible value of this forum! I have ordered new axles and should have them in several weeks. I'll keep working on the brake line routing in the meantime. This is going to be tight timing for our first ever rally (Moraine in Illinois June 8). Keep the advice coming! Doug
Old 04-13-2007, 11:25 PM   #11
Salem , Oregon
Images: 18
Hi, I've heard this several times; "Routing the brake lines" I haven't seen these kits, but I can't believe this kit does not have instructions and diagrams showing how and where to run the hydraulic lines. I see big problems, down the road, if everyone out there runs the brakes lines however they want to. Brakes are a major safety item and should be installed consistantly or by a certified brake technician.
2005 Safari 25-B
Old 04-14-2007, 02:09 PM   #12
2008 31' Classic
Yet another question
I believe I have found a good arrangement for locating the brackets for the flexible hose connection. I wanted to avoid a "loop" in the direction of travel and I think this will work nicely. For the front brake I can feed the steel line up between the tank and the frame so it's protected. For the rear brake I can do a 180 turn to get the brake line between the frame and tank. Both of these positions appear to provide adequate flex and travel of the flexible hose. Any concerns / thoughts before I charge ahead? (these pictures still show the old, worn out axles ... actually helps me with the positioning of the brackets since it's the mid point of the rotation of the spindle on the axle.)
Name:	Wheel Well 008.jpg
ID:	35604   Click image for larger version
Name:	Wheel Well 010.jpg
Name:	Wheel Well 011.jpg
ID:	35606   Click image for larger version
Name:	Wheel Well 013.jpg
Name:	Wheel Well 014.jpg
ID:	35608   Click image for larger version
Name:	Wheel Well 016.jpg
Old 04-14-2007, 03:29 PM   #13
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Shocks O.K.?? now would be the time!
www.popasmoke.com
YETI ( 65 Quart )
Old 04-14-2007, 03:36 PM   #14
_
hi sunset coast...
in time for the rally? ah brakes are over rated and it's mostly flat 2 illinois, anyway...
imo the final bracket needs to be closer to the hub assembly..
and with the lines up further, away from potential debris or snagging issues...
lost of pics posted on line/bracket positions...
here for example...
showing both inner and outer rail options...
http://www.airforums.com/forums/f439...ics-30727.html
the pix i posts (long skinny ones) r small but can be opened in a new window for a LARGER view...
and in some of the restoration threads...
perhaps uwe thread?
cheers
2air'
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
