Old 08-18-2004, 08:31 PM   #15
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by 71tradewind
The concern may stem from the fact that once the vehicle is stopped ,you can continue to press " with moderate force" the pedal towards the floor and the hydro-boost allows the pedal to continue moving till its almost bottomed out on the floor.This is not something people normally do ,I own 2 vehicles with hydro-boost and both do this.
This is exactly what this guy on the open roads forum was talking about. If the pedal does go as far as it is anticipated and I understand the way the Jordan works, this could/would in fact be an issue with the Jordan with a vehicle equipped with the hydroboost brakes since the travel is limted and hence the concern. Granted I have not yet seen this happen on our new '04 Suburban 3/4 ton, then again, it only has 400 miles on it.
Old 08-19-2004, 07:13 AM   #16
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
That may be easily over come by a Spring. Enough tension under normal condition that the spring does not expand but once the cable runs out of travel it will have some give a the end instead of slipping the jacket in its retainer.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-19-2004, 02:34 PM   #17
Aluminut
2004 25' Safari
. , Illinois
Just an update. I have been messing around with the brakes trying to see how much brake pedal travel I could get.
Bottom line is that the brake travel is exactly as those have described. If the Jordan is based off the pedal movement, I can tell you first hand that the Jordan might not be the controller of choice in this application.
Additionally, I was reading on the truck forums that a guy that has hydroboost lost his powersteering pump....as a result, he also lost his power brakes!
After spending about a month looking at the controller issue, I've come to the conclusion that the Prodigy is the right way to go in this particular situation.
Old 10-01-2004, 12:44 PM   #18
HowieE's Avatar
Princeton , New Jersey
Images: 12
The limitation of the Jordan controller in a GM installation is the fact that the Jordan cable is designed to travel only 1 in through full application. There is no easy way to mount the cable pull to a GM brake pedal that will give this 1 in. of travel because of the location of the streering column support. If you mount the cable pull below the steering column suppot you will see close to 2 ins. of travel in full application of the brakes. This results in the trailer brakes being fully applied long before the truck brakes are fully applied, thus defeating the true proportionality of the Jordan.
To overcome this problem I made a pulley that results in a 2 to 1 reduction of the cable travel from the brake pedal arm to the Jordan controller. This makes the truck and trailer brakes work in complete sink. Take a look at my web page for some pictures.
2004 Excursion 4x4
Old 10-01-2004, 02:04 PM   #19
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We need to be careful here not to say that all GM tow vehicles have this problem. In my case with the van, my Jordan has very good access to the brake pedal.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-02-2004, 07:43 AM   #20
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I did something similar with a lever. I installed a small spring to make sure the controller would always return to the off position. I also moved the controller to the left side of the steering column. On this side I could mount it a little closer to the steering column and a bit higher. Also, since the cable enters the controller on the right hand side, putting the controller on the left side of the steering column makes for a staighter run. I think that the instructions say the controller can be mounted up to 18" either side of the brake pedal with the cable in a lazy S, but I had trouble getting it to work at about 12" to the side. Right now it's only a few inches off the centre of the brake pedal and it works well. The only drawback I've found to having the controller on the left side is that it's more likely to be in direct sunlight which makes it a bit hard to read.
Now that I've made these changes I'm happy with the way the Jordan works, but I think that if I had known I was going to have to go through all this I would have looked more closely at the BrakeSmart.
Grant
1999 Suburban 1500
1964 Overlander
ID:	8955   Click image for larger version
DavidsonOverlander is offline   Reply With Quote
Old 10-02-2004, 06:24 PM   #21
Aluminut
2004 25' Safari
. , Illinois
I'd have to agree. Going into it, I have little desire to mod out the car to make the Jordan work. I'll be getting another Prodigy since it works extremely well with the Safari.
Thanks for all the input. If anyone knows where I can get my hands on a new Prodigy at a good price, please post or PM me.
Old 10-02-2004, 07:34 PM   #22
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hydroboost
Twink - Re the loss of powersteering and brake assist. My Astro has the brake assist coming from the powersteering pump, that's the "hydro" part of the pump. They're one and the same.
Marc
New Water Heater- Suburban vs Atwood PizzaChop Water Heaters, Filters & Pumps 5 02-26-2004 04:48 AM
Info Request from Suburban Owners MileHigh On The Road... 32 01-28-2004 06:16 PM
Suburban 3rd seat TomW On The Road... 1 01-21-2004 05:04 PM
