Old 11-13-2011, 10:04 AM   #29
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by nickmeloy View Post
We installed banjo fittings on our 2006 Classic to solve the kinked brake hose problem. These fittings are equivalent to a 90 degree fitting.
Nick
Nick,
Any chance to post a picture, I'd like to see this, sounds interesting.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 11-13-2011, 10:44 AM   #30
Maniacal Engineer
barts's Avatar
Menlo Park , California
Originally Posted by GCinSC2 View Post
Using the same "plumbing" on our TV's we should expect the same:
"the effect of brake hose compliance on our trailers is to create more brake delay on application, and slightly reduce the speed with which the brakes are released."
I do not see this as my TV's braking habits or expectations. My 2005 Dodge has about 120,000 miles on the original brakes, performing as I expect them to.
The areas that I would advise an owner with disc brakes to review:
Controller to actuator compatibility, must be checked. My dealer sold me an incompatible (non listed) controller, why, I think they were just not used to working with disc systems. Now I have Maxbrake.
Wiring, wiring and wiring. These connections must be 1st class.
Hoses, several discussions here about short hoses and their problems.
And for the possibly most challanging, are your brakes COMPLETELY bled? While my profession is not braking, my profession DOES involve another DOT 3 based single stroke hydraulic systems (automotive clutches) and I cannot over emphasize how important and detremental air bubbles are in these systems. In our TV brakes, we use a single (master cylinder) stroke to create braking pressure in the lines but in our trailer the controller tells the actuator to run and the trailer could be 1/2 air in the lines and the pump just keeps pumping and pumping compressing the air in the lines and eventually (read delay) creating braking pressure. Also a possible source of brake delay in a correctly functioning hydraulic system would be rotor runout. If excessive runout existed the caliper pistons would be slightly in a retracted position as the wobbling rotor pushes the pads away from the runout. This extra air gap requires more time to press the pads against the rotor compared to a true running rotor that had a minimum gap.
I wish I had an ultrasound gizmo that I could put on the system and from the outside detect or prove that air exists in these systems, ain't got it. Air = delay, period.
I will comfortably state that IMHO the mere flow of DOT 3 out of a bleed screw is not a guarntee that all air has been expelled.
Going back to the OP's original complaint of intermittant brake locking up or drag IMHO a single wheel incident must point to components confined to the indivudual wheels brake components and supply hose.
You're right: air == delay. Air introduces compliance into the system and this is what causes delay as the pump has to work to pump up the pressure. Hoses also cause delay because they're springy. [Stainless steel hoses are less springy, but not so you'd notice in this application; one can definitely feel the difference on a motorcycle, for example] There's of course some delay inherent in the movement of the pucks against the rotors.
I bleed the brakes using a remote switch hooked to the break-away line on the controller. What would really make the job easier is a large bottle of brake fluid arranged to keep the master cylinder full as I purge the individual lines; that way I'm not crawling out from underneath the trailer to refill the master cylinder all the time. I installed the discs when we replaced the axles on the Tin Pickle; it took several round the trailer trips to get the air out of the lines, and I'm sure there's still some in there somewhere.
I'm also considering going to the MAX Brake controller; my Prodigy has been fooled into surging in stop and traffic on downhills, which is annoying but not dangerous.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 11-14-2011, 04:35 AM   #31
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Wellfleet , Massachusetts
It is important to be sure you have good clean fluid in the brakes. Contaminated fluid will reduce the effectiveness of the braking system. Fluid also absorbs moisture . I would recomend flushing and bleeding the brakes every other year for best results . If the master cylinder has no check valve in it you can use a vacuum pump at the caliper bleeder . If it does you will need a pressure bleeder at the master cylinder .
Don
Don.44 is offline   Reply With Quote
Old 11-14-2011, 10:03 AM   #32
2006 30' Classic
Milton , Florida
Banjo Fitting
Nick,
Gary
I do not have picture capability. However, the following link to an automotive video may prove instructive.
Video: How to Remove the Banjo Bolt | eHow.com
Nick
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 11-14-2011, 09:06 PM   #33
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I think Airstream still sells a drum brake conversion kit.
Name:	drum brakes-200.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-15-2011, 05:35 PM   #34
GCinSC2's Avatar
Nick,
I know what the banjo bolt fitting is and looks like, I just was curious how your line routing looked using the banjo bolt approach.
Gary
S/OS #001
Old 11-15-2011, 07:04 PM   #35
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
UMMM....wonder why?
Model: 2012 - 31'W CLASSIC LIMITED DINETTE TRAILER
CHASSIS
10,000# GVWR • 10,000# Axle System • 7174# UBW • 2826# NCC • 805# Hitch Weight • Aluminum Wheels • 15" Radial Black Wall Tires, LRD • 12" Electric Drum Brakes w/ Nev-R-Adjust Brakes & Nev-R-Lube Hubs • Electric Hitch Jack • Manual Stabilizer Jack w/Pads • Aluminum Step w/Extension • Stainless Steel A-Frame Protectors • Spare Tire & Bracket.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-16-2011, 02:13 AM   #36
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
I didn't think the surface on the caliper was machined for a banjo bolt fitting but if it works you can't argue with that . I have 90 degree fittings screwed into my calipers and they work fine .
Don
Old 11-16-2011, 10:27 AM   #37
2006 30' Classic
Milton , Florida
Nick,
Gary
The brake hose comes straight from the banjo fitting fitting to the existing steel brake line. The tricky part is getting the length of the brake hose correct. Too short and something will break when the tire goes through its' maxium verticle travel. Too long and one is back into the danger of the brake hose rubbing on something. From memory, my brake hose length is 12 inches, but measuring is critical, and each trailer is probably slightly different.
I also purchased some of that split wire protection stuff from Radio Shack and put a piece around each brake hose, held in place with nylon tie straps.
Nick
F. A. Meloy
2006 30' Classic
Old 11-16-2011, 06:08 PM   #38
GCinSC2's Avatar
Nick,
When I reconfirured my hose, I just didn't think of a banjo fitting config. I can see the idea in my head, a pic would be nice. I used a hose and a short piece of pre-flared steel line going from M10 to 3/8", picture already posted.
One feature that your banjo connection and my steel line attaching to the caliper allows is inboard caliper bleeding in addition to the bleed screw.
But if I started over on this, I would look at approaching this from the front of the axle, somehow routing it down the trailing arm and then attaching. For a comparison look at a motorcycles rear brake. The hose does not come in from behind to the caliper, it comes down the swingarm.
I have a set of new Dexter calipers in the garage, I'll take a picture of the connection, M10 bubble then others can see the face of the caliper casting at the connection.
S/OS #001
Old 11-17-2011, 09:39 AM   #39
2006 30' Classic
Milton , Florida
Don
You are correct in that the casting is not machined to a very smooth surface. Another member of the forum had sent me a PM on his success with using banjo fittings in this application. I decided to try it, and have had no problems with fluid leaks.
I went to banjo fittings because I was unable to locate any 90 degree fittings with the correct threads. If memory serves me correctly, the threads are metric on one end and SAE on the other end. Where did you find the 90 degree fittings?
Nick
F. A. Meloy
2006 30' Classic
Electric over Hydraulic/disc brakes Phil Gobie Brakes & Brake Controllers 12 10-13-2017 02:03 PM
1977 Hydraulic Disc Brakes? Atlantica Brakes & Brake Controllers 22 11-20-2007 09:49 PM
Hydraulic disc brakes failed Gator1 Brakes & Brake Controllers 1 03-13-2007 09:19 PM
Kodiak Hydraulic disc brakes thenewkid64 Brakes & Brake Controllers 1 07-06-2004 10:48 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
