Old 02-27-2006, 05:10 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Hydraulic brakes?
Am thinking about buying this trailer. The owner tells me it has hydraulic brakes and not electric. Can anyone tell me what my truck as to have to operate hydraulic brakes?
http://www.airforums.com/class...ct=1485&cat=12
wacnstac is offline   Reply With Quote
Old 02-27-2006, 06:32 PM   #2
Darol Ingalls's Avatar
That trailer would not have hydraulic brakes. Probably he meant disc brakes which are operated with a vacuum line from the tow vehicle. If you have a diesel pickup, you will most likely have to have a vacuum pump installed and a different type of brake control. I would consider removing the disc brakes and replacing them with electric drum brakes. The vacuum control and connection at the hitch will cause you trouble in the future, guaranteed.
Darol Ingalls is offline   Reply With Quote
Old 02-27-2006, 07:12 PM   #3
Somewhere , Indiana
Keep the disc!
If they are hydraulic or hydraulic disc - you can purchase an electric/hydraulic actuator for around $500.00 new. This will allow the brakes to function in conjunction with a standard brake controller. If they are disc's (I kind of doubt it) they will stop about 50% better than electric. If they are straight hydraulic (non-disc) I would most likely switch to electric.
Just two cents from a RETIRED axleman.
Regards,
Henry
axleman is offline   Reply With Quote
Old 02-27-2006, 07:16 PM   #4
Images: 43
Well I plan on towing this thing twice, once to my house and once to it's final resting place so there's no way I'd spend $500 on an electric to hydraulic converter. My truck has no hydraulic line to the back.
Old 02-27-2006, 07:18 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Darol,
I disagree, if the trailer has disc brakes they should stay. Disc brakes are much better than drum brakes. The addition of a new master cylinder pump in the trailer and maybe a new controller in the tow vehicle is all that is needed. The pump is about $500 to $750. New Airstreams come with disc brakes, either standard or optional.
Bill
Just my personal opinion
Old 02-27-2006, 07:19 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
How far do you have to tow the trailer and over what type of roads?
Bill
Old 02-27-2006, 07:20 PM   #7
Somewhere , Indiana
Originally Posted by wkerfoot
Darol,
I disagree, if the trailer has disc brakes they should stay. Disc brakes are much better than drum brakes. Bill
Well said Bill!
Henry
Old 02-27-2006, 07:34 PM   #8
Images: 43
Disc are definitely better than drums but I sure wouldn't put the money into an electric to hydraulic converter kit. The trailer would be towed a maximum of 500 miles total over 99% flat land. There are a few small river valleys that would need to be crossed but in Michigan they are nothing major.
Old 02-27-2006, 07:35 PM   #9
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
All that is required to operate the hydraulic is a source of vacuum, either from the engine or a pump. I kept my disc brakes and removed the vacuum/hydraulic unit. I replaced that with an electric/hydraulic.
I towed our trailer 70 miles, part over mountain roads, with no brakes and no sway bar. We made but admittedly we took a chance.
To get the hydraulic brakes working does take some effort and cost so it ultimately comes down to what you want to do.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 02-27-2006, 07:54 PM   #10
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Then I would stay off of the interstates, take local roads, don't be in a hurry and leave plenty of room in front of you. You didn't mention your tow vehicle, that might change my mind. As did Buttercup, I towed my 1979 23' Safari home to So Cal from outside Sacramento, about 400 miles, without brakes behind my PowerWagon. Not something I would recommend. The only hills we encountered were Techapachi and the five mile Castaic grade coming into LA.
However, make sure that the wheel bearings are recently repacked.
Bill
Old 02-27-2006, 07:57 PM   #11
Images: 43
Would be towing with a 2003 Expedition with trailer tow package and 5.4 engine. Why the advise to stay off the interstates? It is because of passing tractor trailers? I would be using WD/anti sway. Seems like the interstate might provide more gradual braking situations.
Old 02-27-2006, 08:24 PM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
One the speed will be slower, two if the trailer starts to sway you cannot stop the sway since you have no brakes on the trailer. I brought the 1954 29' Liner to So Cal from Tampa with brakes. I might have considered no brakes if the trailer had been shorter, but without brakes there would be no way to bring it back in line.
See: http://www.airforums.com/forums/163666-post1.html
Bill
Old 02-27-2006, 08:40 PM   #13
Images: 43
Won't the WD/anti sway hitch help out with this?
Old 02-27-2006, 08:46 PM   #14
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Yes, it will help, but brakes or low speed will be an additional element of safety.
Bill
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
