Old 03-25-2006, 07:15 PM   #29
1978 31' Excella 500
Goose Creek , South Carolina
I have the hydra-vac on my coach, in the 2 plus years of ownership I have never used them ( I will change that in the near future). I have pulled over 3000 miles this way and although brakes are nice, I belive that it would be ok to go without brakes if you drive accordingly. I would not go on the backroads, there will be more trafficlights and other conditions that would force one to stop. Stay on the freeway in the right lane, leave plenty of space between you and the next vehicle and use your transmission to help slow you down. Since this coach is going to a permanent resting spot it would be hard to justify the expense of upgrading the braking system.
Don't flame me too hard, brakes are a vital part of save towing and the size of the tow vehicle also plays into this. In my case I'm using a 4x4 1 Ton Dually Diesel, my truck weight is more than the coach and the brakes are large and well maintained.
Holzarbeiter is offline   Reply With Quote
Old 03-26-2006, 02:42 AM   #30
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If this is a 70's type unit, it has hydrallic disk brakes. All that is needed is a vacuum line from the manifold. If you are never going to tow the thing again I would not bother if it is smaller than 28 foot. A big one may be snakey without brakes and an inexperienced tower. If you can, maybe you should hire an experienced person with a big truck to tow it for you. In the long run you should follow the lead of most other owners (including me) and replace the antique hydrallics with conventional electrics for a total cost of $350 for parts and one afternoon's labor.
Old 03-26-2006, 10:30 AM   #31
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
After having towed my Overlander with the new disc brakes, I would never go back to electric drums. My advice would be to simply add a electro-hydraulic actuator in the location of the hydravac. Disc brakes are definitely far superior in braking performance than drum brakes, especially electric drum brakes.
Uwe
www.area63productions.com
Old 03-26-2006, 04:39 PM   #32
WayWard Wind's Avatar
2004 25' Safari
It might be over kill as we're towing a 25 Safari, but just the same we're set to have the brakes upgraded the middle of April at the mother ship. I've heard nothing but good results from those who have already had the upgrade.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 03-26-2006, 06:36 PM   #33
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Best,
I don't think that it's overkill at all. A 25 Safari is not a very light trailer, and the disc brake upgrade will more than likely make a huge difference in trailering safety.
My Overlander is a 63 vintage, lighter than the 25 Safari, and it is a joy to tow with the disc brakes. Especially since I tow with a 97 Suburban 1500, which is not kown to have the best brakes in the industry. It might not be a big improvement with a larger truck that has upgraded brakes. Still, though, I like the idea that I can descent very long and steep grades, tapping the trailer's disc brakes to slow down the entire rig without noticeable fade, which was not the case with my previous trailer's brand new electric brakes. Crossing the Rockies had me scared a few times. Which is why I went with teh discs on my 63 during the rebuild.
Uwe
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
