Old 02-27-2006, 09:11 PM   #15
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by wacnstac
Am thinking about buying this trailer. The owner tells me it has hydraulic brakes and not electric. Can anyone tell me what my truck as to have to operate hydraulic brakes?
You have Excella HydraVac disc brakes and they will outperform any electric drum brake on the market. The discs are huge/heavy and are awesome. How do I know? I had them on my '77 Excella 500. Andy at Inland RV in Carona, CA. has parts for the units. I used my 31' '77 coach for about 5,500 miles over a 4 1/2 yr. period and never had a problem. Matter of fact, I never noticed any wear on the pads when I was repacking the bearings over the ownership period. The brakes functioned flawlessly.
I used an engine vacuum port off the manifold on my '92 Z71 4X4 and the same off my '01 2500hd 4X4 Chevy trucks. I used Air Brake hose and a check valve about one foot from the engine manifold source. All brass connections were used except for the 1/2" industrial male/female couplings at the bumper where the vacuum source connected to the hose going to the vacuum booster system on the trailer tongue. This is also your emergency brake system should the trailer seperate from the vehicle. If you do a search for the HydraVac disc brake system you will find some of my posts on parts I used. I never had a problem. That trailer is in Hamburg, Germany now.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-27-2006, 09:34 PM   #16
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Not likely that I'll find a vacuum line to run back there from my expedition.
wacnstac is offline   Reply With Quote
Old 02-27-2006, 09:39 PM   #17
_
disc brake on airstreams....
hi guys i really like the discs for all the reasons listed...
while airstream is using them again (mid 05 up) on the classics...this isn't new...yes those mid/late 70s had 'em...
this is the 2nd or 3rd wave of airstreams using discs...for a few years then switching back to drums....hopefully they will move other models to discs as well...
i have seen a new bambi with a disc brake upgrade........sweet.
cheers
2air'
Old 02-27-2006, 10:31 PM   #18
davidz71's Avatar
1986 25' Sovereign
I don't understand your statement? If you have a gas engine then you have a vacuum port somewhere on the manifold. You tap into it with threaded fittings and use barbed fittings which slip into airbrake hose along with hose clamps. You run the airbrake hose inside the frame rail back to the rear bumper. Simple job. I posted pictures of the entire setup on the forum.
Craig
AIR #0078
3.73 rear end
Old 02-28-2006, 05:27 AM   #19
Images: 43
Link please.....
Old 02-28-2006, 05:28 AM   #20
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by axleman
If they are hydraulic or hydraulic disc - you can purchase an electric/hydraulic actuator for around $500.00 new. This will allow the brakes to function in conjunction with a standard brake controller. If they are disc's (I kind of doubt it) they will stop about 50% better than electric. If they are straight hydraulic (non-disc) I would most likely switch to electric.
Just two cents from a RETIRED axleman.
Regards,
Henry
Henry, one of our unit members was attending the rally last week, and they had a 1976 Excella that was originally equipped with hydraulic brakes, IIRC they were discs. It is a rare feature, but they are out there. They converted to electric drum brakes, and were happy with the result, as the hydraulic system always gave them problems. Personally, I also would want to keep the discs, because they will stop better, and are easier to replace pads on when they wear out.
Old 02-28-2006, 08:02 AM   #21
StingrayL82's Avatar
San Angelo , Texas
Images: 37
I don't know if this system is the same or not, but we hauled Brooke's car back from Boise on a U-Haul flatbed with hydraulic brakes, and it was the worst brake system I have ever seen. They didn't kick in right away, and I felt like the truck was still doing most of the stopping. I'll take electric drums anyday over that setup.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 02-28-2006, 08:24 AM   #22
J&C
J&C's Avatar
2002 31' Classic
Hillsboro , Texas
Images: 11
U-Hauls are commercial trailers for the masses, they operate on a simple "surge" principal, you cannot compair the disc/hydrallics used on private vehicles and trailers.
JB
J&C is offline   Reply With Quote
Old 02-28-2006, 11:26 AM   #23
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Fredric,
Based on your description those brakes were not set up correctly either. If they were surge the shoe(s) was not adjusted correctly. Self adjuster not working. If a disc set up and surge, the system had major issues like air in the lines or contamination.
>>>>>>>>>>>Action
Old 02-28-2006, 05:40 PM   #24
Somewhere , Indiana
Wow!
Terry,
Thanks - that's good info. The thread started with hydraulic brakes - not defined as disc or drum. I have seen older Airstreams with hydraulic drums, GT6921 has/had one. I have not seen older units with discs though. Thus, I appreciate your knowledge on the topic.
Best Regards,
Henry
axleman is offline   Reply With Quote
Old 02-28-2006, 09:15 PM   #25
davidz71's Avatar
1986 25' Sovereign
Link please.....
http://www.airforums.com/forum...ht=disc+brakes
Craig
AIR #0078
3.73 rear end
Old 02-28-2006, 09:27 PM   #26
davidz71's Avatar
1986 25' Sovereign
Link please.....
Here are a few shots from the back area of the engine manifold as the air rake hose snakes its way back towards the rear of the vehicle. The blue covering is wire loom over the hose to protect it from any abrasion.
ID:	18829   Click image for larger version
ID:	18831   Click image for larger version
ID:	18833   Click image for larger version
ID:	18835   Click image for larger version
Craig
AIR #0078
3.73 rear end
Old 02-28-2006, 09:41 PM   #27
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
My haurralic actuator can go from 0 to full pressure(1600 psi) in half a second. I can tell you from experience that full pressure is more than enough to lock the wheels. So if I only really need to go to - say, half pressure - It takes less time to get there.
Hydraulic is fast. Maybe not as fast as electric. But fast enough and certainly strong enough. That's why I didn't swap over to electric when I replaced my axles.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 03-01-2006, 06:02 AM   #28
davidz71's Avatar
1986 25' Sovereign
If you have the money, buy one of the brake actuators (do a forum search on that also because there has been much discussion), remove the brake booster equipment mounted on the tongue, bolt the new actuator up to the hydraulic lines and then wire it up. This way you do not have to run the vacuum line from the front of the vehicle. I didn't have the money to buy one so I did it the old fashion way. It will cost you over $1,000 to switch from your current brake system to electric and you will be going backwards in performance.
Craig
AIR #0078
3.73 rear end
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
