Old 10-06-2007, 04:21 AM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
hydraulic brake noise
2008 s/o
electric-hydraulic brakes
P3 controller
brakes weren't making noise at prep/delivery- but did seem to have a delayed response...
2 hr drive home... backing up parking... brakes sound like an upright vacuum cleaner... maybe louder even, over the noise of the 496 big block
boondockdad is offline   Reply With Quote
Old 10-06-2007, 05:18 AM   #2
Dearborn , Michigan
Images: 21
could this be a bleed issue... actibrake manual requires a second bleed after first 100 miles...
Old 10-06-2007, 09:04 AM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by finalcutjoe
2008 s/o
P3 controller
The actibrake will make some noise, after all it is a substantial electric motor and a high pressure pump. Typically, you can not hear it inside the truck while towing, but you can hear it from the outside of the trailer.
If it is louder than a hum, then there might be something wrong with the pump.
Uwe
www.area63productions.com
Old 10-11-2007, 04:24 AM   #4
Dearborn , Michigan
Images: 21
talked with Mike at actibrake... said the pump is noisy... but thats the tradeoff for getting 1600psi to the calipers...
the brake response time is a good 2-3 second delay... not good
adjusting the gain, i can lock 'em up no problem... dialing it down, i can get them to stop the whole rig beautifully... but there's that delayed response...
Mike was 99% sure its a bleed issue...
bled lines last night... looked like root beer float coming out of there, lots of air and foam.... i wasn't able to hook up and test it... will be pulling it this weekend... i'm sure that was the problem...
Stromburg Hydraulic Brake Actuator aprimosch Brakes & Brake Controllers 4 06-19-2007 01:32 PM
Noise flyguy Batteries, Univolts, Converters & Inverters 5 06-07-2007 04:56 AM
Hydraulic brakes? wacnstac Brakes & Brake Controllers 32 03-26-2006 06:36 PM
hydraulic brakes wayne.yl Brakes & Brake Controllers 3 07-08-2004 08:23 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
