Old 01-17-2012, 10:49 AM   #1
Bandits's Avatar
2008 30' Classic
Hydraulic brake lines
First the disclaimer: I am not an expert on any kind of brakes and am only offering information on an issue I addressed on my Airstream 2008 30' Classic with hydraulic disc brakes . I would recommend that everyone interested consult with a brake specialist before proceeding with any issues related to brakes. What I'm reporting on is an issue pertaining to my unit only and what I did to resolve the problem.
On the recommendation of a friend, A fellow Airstreamer with the same hydraulic brake system, I checked mine and found the identical problem. The rubber hydraulic lines were too short to allow them to be installed with a proper bend when connected to the top of the caliper. This resulted in a very sharp bend which constantly flexed as the wheel bounced up and down. My trailer has about 9000 miles on it and already the 2 of the lines were showing signs of failure at the bend.
My solution was to have stainless braided lines fabricated a couple of inches longer which allowed a much larger radius bend to where the line connects to the caliper. I also had the lines fabricated with a 90 degree elbow where the line attaches to the distribution manifold. The new lines were fabricated here in Tampa while I waited. A simple look should verify if your lines were installed as were mine.
Jerry, Irene & Clancy
Bandits is offline   Reply With Quote
Old 01-17-2012, 10:54 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can also move the mount for the steel brake line 1" closer to the axle, which will ease the bend on your existing hose.4 self-tapping screws are cheaper than 4 new hoses.
Old 01-17-2012, 06:17 PM   #3
Denis4x4's Avatar
Durango , Colorado
These are over the counter items at any good speed shop or mail order from Jeg's, Summit or Speedway Motors at reasonble prices.
Denis4x4 is offline   Reply With Quote
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Hydraulic leveling system. boatdoc Jacks, Stabilizers, Lifting and Leveling 18 02-08-2011 05:30 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
