Old 06-04-2006, 04:56 PM   #1
1978 31' Excella 500
lv , Nevada
Hydra Vac or Hydra Electric
Fellow Streamers;
I just bought a 31' 78 excella 500 that has been sitting
for 14 years.My tv is an 05' GMC duramax.How do I use the
hydra vac brake system with a diesel.Do I need a vacuum
pump?Also,which electric actuator is best.Thanks.
richnritab is offline   Reply With Quote
Old 06-04-2006, 06:13 PM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
After 14 years ya gotta wonder if the brakes are going to work at all. I bet the calipers are frozen. You need to do a thorough inspection of the rotors, calipers, and master cylinder located behind the propane tanks. We had a '77 that was in continual towing use, and in less than 10 years the brakes were converted to electric because they were no longer functioning. Today's hydraulic brakes work on an electrical input to a hydraulic actuator vice vacuum actuated. So with a diesel with no vacuum, your installed setup won't work. Your original brake system that hasn't been used... probably doesn't work either. Convert to electric brakes $$ or go with the latest disc brake technology $$$. Good luck and let us know the progress.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-04-2006, 08:09 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
99% of the owners of that kind of braking system (including myself) have converted them to electric. You can not get parts to maintain them. I gave up after the caliper holder brackets failed due to poor welds and fatique failures. If you want some of my old parts: I have 50 pounds of rotors, calipers and vacuum to hydrallic converter. You pay for my packing and shipping.
Old 06-06-2006, 07:12 PM   #4
lv , Nevada
Thanks for the reply.If I go with an electric actuator( if I decide to keep the
hydralic system) which one is the best.Are there after market brake parts
that will work within this system.Im trying to set this up with the best brake
controller to the best actuator.Im mean the best working combination.Im
brand new at this.I don't know were to by parts.I've been to three places
here in las vegas and it seems they have to order parts.No one has been
very helpful.I can't wait to get on the road but I want to do it right.thanks
again.
Old 06-06-2006, 07:21 PM   #5
lv , Nevada
Dwight would you give me your address or phone.I might take you up on that offer.My phone is 702 3681956.OR cell 7022779189(That is if you weren't
just making a point.)I really appreciate it.
Old 06-06-2006, 07:26 PM   #6
Somewhere , Indiana
Curious?
Are we talking hydraulic disc or drum?
Please inform,
Henry
axleman is offline   Reply With Quote
Old 06-06-2006, 07:44 PM   #7
lv , Nevada
Hydraulic disc.
Old 06-06-2006, 07:48 PM   #8
Somewhere , Indiana
Go disc!
I suspected that but did not want to assume. Disc brakes are far better than electric - a bit more pricy but far far better.
I would keep the disc system if possible - if not - perhaps you want to think about converting to the Kodiak disc system.
Just two cents from a retired Axleman.
Regards,
Henry
Old 06-06-2006, 07:57 PM   #9
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
You have exactly what I was faced with. In the end I opted to replace the hyd/vac unit with an electro/hydraulic unit. I made a comparison of a few of the brands out there and published those results based on the information that was available on the net at the time. There may be more actuators out there that I don't know about.
End result - I have a Dexter unit that I am quite happy with. I documented my actuator replacement at http://overlander.archnevada.com/index.php?brakes and my caliper work at http://overlander.archnevada.com/ind...?brakecalipers.
As mentioned above you should definitely rebuild your calipers with new pistons and boots.
When it comes to actuators you should compare all features for yourself and come to your own conclusion as to what you want to have. Don't rely too much on anecdotal evidence as to which is the best. Work hard to educate yourself but don't go crazy. Just because I love my unit doesn't mean that it will be the best for your needs.
Also make sure that the brake controller you get is matched with the actuator unit you get. Most actuators get along with differing brands of controllers but be sure.
And if you get in a bind or feel hopelessly lost - always feel free to ask here on the forums.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 06-06-2006, 08:00 PM   #10
lv , Nevada
By all means my intention is to stay with the discs.However I need info on the best way to do it.Which electic actuator would work best.Where do I get it.How much $$$ are we talking about.
Old 06-06-2006, 08:03 PM   #11
lv , Nevada
Thanks buttercup your a real sweetie.I'll take a look at that site.Thanks.
Old 06-06-2006, 08:54 PM   #12
lv , Nevada
Butter cup were are you ordering parts from.
Old 06-06-2006, 08:57 PM   #13
lv , Nevada
I checked out your site.Thats worth a million.
Old 06-06-2006, 11:06 PM   #14
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I'll tell my wife you called me sweetie. Fortunately Buttercup is the trailers name. However, I have been called other names by co-workers.....
I kept my calipers, electing to rebuild them. I got the pistons, seals and boots from InlandRV because they had them. One thing about pistons is that they are usually steel plated with a tougher metal by some process such as flame spraying. Once that is done the finished piece is machined down to size. Well any pitting on the pistons (even after this process) will certainly mean early failure. The ones I got from Inland had some pitting which looked like it was related to the plating process more than anything else. I do not expect failure but wherever you get the pistons inspect them carefully. Your pistons may be in good enough shape to reuse. Mine were not. I had one that was O.K. but I figured that they all should be replaced.
Installing the boots can be a challenge! I used the process from my tech manual and still went through 8 boots to do 4 calipers! I tore through or pinched a hole in them trying to get them on. But that may be a product of my inability to work delicately with my hands when I need to.
I love Disc brakes over just electric brakes for many reasons. So I kept my rotors and repacked my bearings and the whole nine yards. You can get real intimate with your wheels and axles during this process.
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Electric meter dienst1 Airstream Motorhome Forums 4 10-20-2002 09:17 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
VAC Estes Park Rally... InsideOut WBCCI Rallies & Events 6 08-22-2002 12:26 PM
Electric hook up Dbraw Electrical - Systems, Generators, Batteries & Solar 2 07-07-2002 12:56 PM
