Old 07-20-2009, 04:58 PM   #1
Canada , Manitoba
How to inspect the brakes & bearings
I just got my camper this year and I'd like to do some maintenance... Now that I have the wheels off, it's a good time to have a look at the brakes and them bearings. How do I pull these brakes off and what do I look for?
How do I pull out and repack the bearings?
Here are pictures of my brakes...
ID:	84216   Click image for larger version
SnoSheriff is offline   Reply With Quote
Old 07-20-2009, 05:16 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
This is for disc brakes, but the process is similar for drum brakes: Overlander '77 | Repack Bearings | Bearing Repacking
Bill
Just my personal opinion
Old 07-20-2009, 06:50 PM   #3
Canada , Manitoba
On car and truck drum brakes I use a hammer. But I don't want to damage anything so how do I pull off these drums?
Old 07-20-2009, 07:28 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Maybe this will help...go for it.
RV, BOAT, UTILITY TRAILER AXLE DIAGRAMS AND EXPLANATION OF PARTS
trailer wheel bearings - Google Videos
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 07-20-2009, 07:33 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
After you remove the dust cap, cotter pin and nut, the drum should come right off with a little wiggling, they always have for me anyway. The only issue can be if the brake shoes are adjusted too tight.
Bill
Old 07-20-2009, 08:59 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
And if the shoes are holding the drum on, get behind the backer plates, pull off the rubber cover at the bottom, turn the wheel inside to loosen the shoes. It is inevitable that you will turn them the wrong way the first time, and then the drum won't rotate at all, then go the other way until the drum moves freely. After you drop the rubber cover in the dirt don't forget to find it and put it in a safe place.
Gene
Old 07-20-2009, 10:30 PM   #7
1975 29' Ambassador
Reno , Nevada
see Bearings and the step by step photo gallery at Bryan and Dave's Greasy Adventure. There are some pictures of things to look for as well.
Argosy brakes, bearings ls99 All Argosy Trailers 4 05-31-2008 04:35 PM
Help w/ wheel bearings and brakes. mrmossyone Brakes & Brake Controllers 20 12-15-2007 04:29 PM
'79 26' Argosy Bearings and Brakes IceCactus Axles 4 10-04-2007 01:48 PM
Brakes & Controllers Dan S Brakes & Brake Controllers 6 03-03-2007 04:10 PM
Inspect before you buy tmcdougald Buyer Guidelines 14 07-12-2005 06:50 AM
