Originally Posted by Butcher
I inadvertently pulled the pin on the breakaway switch of my 1974 31 ft Sovereign travel trailer and of course, killed the battery and probably the controller. The brakes are stuck on and won't release. I cut all the wires at the wheels to release the brakes because I couldn't get them to release any other way. My question is: If I re-splice and reconnect the wires, will the brakes lock up again. And if so, how to I get them working again? Thanks.
if the umbilical was disconnected and the brakes stayed applied, the battery wasn't dead.
if the breakaway switch is working properly, the reconnected brakes should be ok, provided that it wasn't long enough to ruin the brake magnets.
polarity does not matter with the wires at the wheels. i'd try testing with just one wheel rewired.
you can do some testing with just the trailer if the battery is ok now. put a jumper wire from the
12v hot to the brake wire at the umbilical end.
