11-23-2018, 07:32 PM
Pearl
, Alaska
How do you thread your emergency brake switch cable to TV ?
Currently threading mine through one of the hitch chains...then to hitch ...quite a bit of slack...any advice???
11-23-2018, 07:45 PM
2016 25' Flying Cloud
Holly Springs
, Mississippi
Yes...shorten the cable. Many will suggest not threading through the chains. I'll be interested to follow this thread to see what others do.
I always heard the break-away cable should be slightly shorter than the chains, so that the plug gets pulled before the chains are at full extension. Otherwise you get no auto braking because the chains engage first.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
11-23-2018, 07:53 PM
Pearl
, Alaska
I should add that the AS dealer threaded mine this way during orientation...looked very sloppy and lots of slack in the cable with gaps that I felt could snag...
On the other hand...on my previous RV , there were times I was nervous that I had not allowed enough play and that a hard turn or such would disengage switch...[emoji41]
11-23-2018, 08:12 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
I thread mine through the hole on the receiver where the chain hooks on, then back to the coupler and fastened with the pin through latch handle. Never thread it through the chain links.
Ray B.
11-23-2018, 08:21 PM
2012 25' FB Flying Cloud
Celina
, Ohio
I put an eye hook in one of the licence plate screw holes and run it through that, this way the AS is directly attached to my TV in case the whole hitch weld comes loose
11-23-2018, 08:53 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Short cable clipped to truck receiver.
11-23-2018, 09:27 PM
2022 25' Flying Cloud
NCR
, Ontario
I thread mine through the hole on the receiver where the chain hooks on, then back to the coupler and the loop goes through the lock that keeps the latch handle closed.
11-23-2018, 09:36 PM
2018 25' International
Mound
I thread mine through a spot on the frame independent of the receiver. Like Castaway, I do it this way in case of receiver failure. I don’t have any problem with extra cable length.
11-24-2018, 05:53 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
11-24-2018, 05:58 AM
2014 25' Flying Cloud
Cuddebackville
, New York
I wrap a few turns around the umbilical cord to take up slack, then put it on the safety chain hook.
2019 Ford Expedition Platinum
11-24-2018, 06:16 AM
Niagara-on-the-Lake
, ON Canada
The emergency brake cable should be short enough that if the trailer comes off the ball and the chains extend the brakes will be active. On my rig the umbilical cord would not disconnect if the chains were fully extended.
Ray B.
11-24-2018, 08:18 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
X2
Never thread thru the chains, never knot the chains to shorten them.
Attach breakaway cable securely to the vehicle, receivers also fail. 🥴
11-24-2018, 08:46 AM
1971 27' Overlander
Kansas City
, Kansas
If you feel really enthusiastic. Cut it to the correct length and re crimp the eye. Then attach it to the receiver with another D shackle.
11-24-2018, 09:50 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
NOT the receiver...😳👎
11-24-2018, 10:39 AM
1987 25' Sovereign
Fort Collins
You want the chains to engage first to prevent complete trailer breakaway — that’s what they’re for. Breakaway switch is to engage trailer brakes if it completely detaches from theTV.
Alumacoot
“We are confronted with insurmountable opportunities.”
11-24-2018, 01:10 PM
1971 27' Overlander
Kansas City
, Kansas
I'm absolutely 100℅ sure that my regular maintenance inspections of my receiver will prevent it from ever falling off.
11-24-2018, 01:44 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Well...go ahead do it your way instead of the correct way, it is your trailer after all. 😂
11-25-2018, 06:53 AM
Atl Bch
Originally Posted by mojo
Was reading all replies, but this one being a coil makes the most sense. And it clips to itself when not in use.
Thanks. I will order this one asap.
11-25-2018, 07:31 AM
2016 23' International
Centennial
For those of you who have purchased and used the Fastway cable, did you buy the 4 foot or 6 foot version?
Steve "Centennial Man"
11-25-2018, 07:37 AM
2018 27' Tommy Bahama
Marana
I purchased the four foot version.
From their site: “The 4′ cables are recommended for bumper pull trailers, and the 6′ cables fit gooseneck or 5th wheel trailers”
https://www.fastwaytrailer.com/zip-breakaway-cable
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
