Old 06-15-2009, 09:52 PM   #1
San Diego , California
Question Hook Emergency Break-away cable to what?
One thing that I never had explained to my satisfaction is how and where is the best way to hook up the emergency break-away brake cable. My A/S came with the cable "woven" through the safety chain. It has a loop on the terminus. I have been locking it's loop with a paddle lock that holds the pin in the channel of the hitch. Is there an accepted or proper way?
Thanks, Randy
OB Bambi is offline   Reply With Quote
Old 06-15-2009, 10:08 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Thanks, Randy
Un-weaver it. and hook it around your bumper. I have had my trailer come un-hitched and the chains break, my brake-a-way saved my trailer. The breaking chain could cut the break-a-way wire. I use a small carabiner type object to connect the loop back on to the wire.
Michelle TAC MT-0
Sarah, Snowball
Old 06-15-2009, 10:14 PM   #3
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Randy:
I loop my cable directly from the break-away switch to the TV bumper, looping it through the license plate opening. I use a snap hook back to the cable right at the bumper to attach it. I do not route the cable through anything between the switch and the TV. I started doing this when I read about some hitches failing at the welds and falling off.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 06-15-2009, 10:20 PM   #4
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
It's not the hitch...
Randy,
I attach ours to a mini carabiner thing that is also attached to an eye-bolt. The eye-bolt is threaded through the license plate mounting screw hole, through the bumper (steel) and fastened with a nut. So it also functions to keep our license plate on. I have read (believe it may have been attributed to Wally) that using the bumper is discouraged. Definitely better then using your hitch and I don't think our bumper is going to be ripped off without pulling the safety cable pin.
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-15-2009, 10:36 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I hook ours to a carabiner that is hooked through a hole in the bottom of the vehicle's bumper.
Brian
SuEllyn & Brian McCabe
Old 06-15-2009, 11:11 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my break-away cable is looped around the receiver and hooked onto itself. [see picture] My cable was originally weaved through one of the chains and worn through while driving on ice and snow. [enlarge picture to see]
Name:	IMG_0689 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-15-2009, 11:24 PM   #7
1975 27' Overlander
High River , Alberta
There's an easier way to do it for cars, vans and SUVs. Attach a chain "repair" link with a couple of washers to the loop in the cable, and just throw it into the trunk when you hook up. As long as you have something on the end to keep it from being pulled through when the lid or hatch is shut, it'll do.
AlbertF is offline   Reply With Quote
Old 02-02-2010, 11:58 AM   #8
1971 23' Safari
Libertyville , Illinois
what is the standard break system for 71 airstream safari?
edirwin is offline   Reply With Quote
Old 02-02-2010, 12:25 PM   #9
Mackhopp's Avatar
2005 28' International CCD
Ottawa , Ontario
We affix the loop onto our axe (it comes along on all camping trips) and just lay it down on the inside of the truck bed.
[SIZE=1]Michelle & family
[COLOR=Blue] 2005 28' International CCD
Mackhopp is offline   Reply With Quote
Old 02-02-2010, 12:52 PM   #10
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
If you don't have an axe ...
Here's an easy way to do it. Make this from a big bolt, a nut, and two washers. About $2 at the hardware store. Toss it into the trunk, rear hatch, or trap it in the pickup tailgate. We featured this idea in the "Great Ideas" department of the Winter 2009 issue of Airstream Life.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 02-02-2010, 01:40 PM   #11
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
When I bought my AS, the dealer showed me how he would do it. I have a Suburban. He told me to put the loop at the end of the wire for the break away switch on (over) the foot for the tongue jack on set it inside the hatch, wha la. In the case of a truck, you could feed it through the tailgate slot and do the same. You didn't mention your TV.
Be safe!
airdreamers is offline   Reply With Quote
Old 02-02-2010, 02:01 PM   #12
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Welcome
We have a 72 and the brake system is electric (12 volt) activated by an aftermarket dash mounted control box.
This thread is referring to an "Emergency Brake away system" that will activate the trailer brakes if the trailer becomes separated from the tow vehicle. Also 12 volt, but power supplied by the trailer battery and a cable activated switch.
With a little more information in your question we could be more help.
Welcome to the Forums keep looking around and use the search function at the top of the page (I like the goggle search).
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 03-02-2010, 01:52 PM   #13
1971 23' Safari
Thanks for the help... so much to learn on the trailer and here!
Old 08-18-2011, 10:18 AM   #14
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
I just wanted to bump this thread as a safety reminder to all. I know an Airstreamer whose hitch separated from the truck while towing. Thankfully, his 34-foot, 4-ton + trailer came to a gentle stop with no injuries or damage because his breakaway cable was hooked to a license plate bolt, not the hitch. There are a lot of solutions offered here on where to attach the breakaway cable. But hooking it to the hitch is not safe. Another simple solution is to replace one of the license plate bolts with an eye bolt, then the breakaway cable can be attached to the eye bolt with a small carabiner.
JBinKC is offline   Reply With Quote
emergency brakes PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 8 08-06-2012 06:02 AM
Emergency help needed! markdoane Batteries, Univolts, Converters & Inverters 10 06-22-2007 08:11 PM
Emergency Winterize!? sarmimi Winter Living 27 10-16-2005 08:02 PM
Break-away cable broke... crazylev On The Road... 9 08-16-2004 06:24 PM
Emergency parts Bill Resseau Mechanics Corner - Engines, Transmission & More... 11 04-23-2003 09:21 PM
