Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 10-06-2002, 02:02 PM   #1
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
Hitch light plugs
Ok all you towing experts. I am getting set to tow my saturn behind my motorhome. The Saturn has the 6 pin light plug, with 3 wires running to it. The Airstream has the flat plug, which I want to replace with a female connector 6 pin. The question is wiring, how do I make sure I am wiring the new 6 pin female jack right.
Too many varying wire colors and 4 wires on the airstream, 3 on the car end. Thanks for any tips or ideas to make this a smooth splice.
Old 10-08-2002, 08:50 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
You may want to get with Fred on this issue. His MH was all setup for dinghy towing and he has the pigtail. He may be able to tell you what pins do what lites. His pigtail looks like the one on the left in your photos.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 10-12-2002, 08:29 PM   #3
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
Send a message via AIM to 1985air345 Send a message via Yahoo to 1985air345
Alan,
I have a sheet titled "A.T.A. & S.A.E. Wiring Codes Recommended Standard"
White - Ground Return
Brown - "3 bar marker (ICC) & tail lamps"
Yellow - Left turn signal
Green - Right turn signal
Here is a photo of my hook-ups. Don't ask me what they are for.
Name:	airstream toad wiring.jpg
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 10-12-2002, 08:40 PM   #4
1985air345's Avatar
Alan,
That sheet also lists the 6-pole markings
White - Ground Return ("GD")
Brown - "Tail (6-pole only) Marker & Clearance lamps" ("TM")
Yellow - Left turn signal ("LT")
Green - Right turn signal ("RT")
Fred H.
Old 10-12-2002, 10:04 PM   #5
Just a member
Images: 21
Fred,
Based on the first pictures the left one is a 7 way plug for towing a trailer equipped with brakes. Like a bambi. The one on the right is for the toad.
Brett G
Dent and replacing light fixtures imeynstein Lights - Interior & Exterior 5 03-30-2004 02:56 PM
help me see the light wheel interested Our Community 1 11-17-2003 08:34 AM
Hitch Rating DaveJ Airstream Motorhome Forums 4 09-18-2003 08:29 PM
Interesting Reese hitch experience... 85MH325 Hitches 25 07-30-2003 06:00 AM
How to choose a shock-absorbing Hitch ? femuse Hitches 4 02-26-2003 09:43 PM
