Originally Posted by Goatboy
UKnlaw says the unit needs to be mounted on the trailer not the TV.
I just don't think we need the TV more than once or twice a year and found a local company offering a tow vechile for next to nothing for a weeks hire.
I just don't understand how the electronic braking mechanism works and whether it would be 'transferable' to different tow vechiles?
Goat,
It's a pretty easy way to go renting TVs & avoid the "care & feeding" of a TV, to rent for limited use. We've been doing so since 2012, but are looking to buy one now that we'll be using ours more, & our TV rentals are not cheap ($120-130/day, $800-1000/wk for Ford F250 & other 3/4 ton crew cab pick-ups at Enterprise Commercial Truck Rental - one of only a couple here who allow towing nowadays).
Get the Tekonsha RF wireless, which the unit mounts on the trailer A-frame, & you plug the pig-tail wire handheld control unit into the ciggy lighter of any TV. Check on any issues with that unit in the UK/Euro market cars with Tekonsha tech people, but I think it works the same.
http://www.tekonsha.com/products/bra...RB508pViEKmVBf
The TV will have to have pin-connector for
12v power + lights, brake lights & signals - but not for brake controller (7th pin/blade), so the Euro 6-pin connectors should work, but 4 pin is only lights so won't, not sure about UK/Euro 5-pin. Check also with Tekonsha tech to be sure.
We've been renting TVs here in SoCal since 2012 using our Tekonsha RF with no problems on our
1960 Avion T20, & I know others with AS that use them too.
The only issue which you may encounter, is needing to use an adapter from the Tekonsha RF's 7-blade USA connector, to your TV's 6-pin, which I think there are Curt, Tow Master, etc. who make them here in the USA for folks with Euro SUVs/Cars that have the Euro spec connectors. You may also may need the Curt or other Light-out circuit bypass adapter at the TV plug, in order to eliminate conflicts of the light-out function with the RF's operating the brakes & allowing the RF to "Pair" with the TV. Tekonsha &/or eTrailer should be able to help with both of those items.
https://www.etrailer.com/Wiring/Tow-Ready/20142.html
Also eTrailer has another adapter that is for the light-out (we got the above one), plus some help articles on the issue with Euro TVs.
They aslo carry a wide range of the other 7-blade to ?-pin adapters - & they sell the Tekonsha RF, as well as all sold at many other vendors. So price check & price match with them or whomever.
There may also be Euro &/or UK versions of the Tekonsha RF &/or other similar trailer mounted brake controllers available over there & usable with less fuss.
Cheers Mate!
Tom
