Old 05-18-2008, 10:42 PM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Highway 1 and brake chatter
On my recent trip from Ferndale over to Fort Bragg (CA) on Hwy 1, it was about an hour of hairpin turns, something that I've never done. About half way, and at speeds under 20 mph, the brakes would grab and chatter. Is this a heat issue, or something that needs repair attention?
bevman is offline   Reply With Quote
Old 05-19-2008, 05:46 AM   #2
Retired.
. , At Large
I think you should take a look at them. It could be something as innocuous as brake dust, or as serious as a brake lining worn off.
My gut feeling is the drums may need machining. The part that may need machining is the flat part the magnets ride on. You do still have electric drum brakes? Discs would be another matter.
Old 05-19-2008, 08:04 AM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Did the problem go away when the brakes cooled down?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-19-2008, 09:07 AM   #4
bevman's Avatar
Yep, they are electric drums, and OLD... got the round magnets. I took off the drums not too long ago to check bearings and brake lining. Linings are more than half thick, so that's good. The magnets have a few more trips still on them. I adjusted the star wheels at that time.
As to the cool-down... I spent the night in Mendocino, and at the front end of the way home the problem reoccurred at slow speeds (cool brakes) but, since the road wasn't nearly as serpentine, it wasn't a problem.
Old 05-19-2008, 11:04 AM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1974 29' Ambassador
Yucca Valley , California
Images: 41
I would take another look at the brakes. Inspect every aspect, and replace the backing plates as a unit if you find worn components. I would also have the drums machined, or get new ones. My 58 flying CLoud has original brakes - they don't work so well either...My plan is to upgrade to discs once the trailer gets more attention. I run discs on my 1963 Overlander. That is one of the best upgrades I have ever done.
Uwe
www.area63productions.com
Old 05-19-2008, 12:31 PM   #6
Excella CM's Avatar
Venice , California
You may have a faulty circuit. Check the wiring for lose or shorted wires at the plugs and in the umbilical. You may be getting uncommanded brake application due to crossed wires.
West Boondocking Gravenstein Highway walter1 Boondocking 0 10-12-2007 03:00 PM
Highway 9 south of Breckenridge silversled On The Road... 3 06-29-2007 11:49 AM
Vibration caused by the highway gilmorris Member Introductions 18 05-29-2006 05:36 PM
