Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 09-05-2007, 08:26 AM   #1
fred bartlet
fred bartlet's Avatar
Profile:  2001 31' Excella
Grand Rapids , Michigan
Question Hensley TruControl Brake Controller?
Has anyone had some experience with the new Hensley controller on the Hyd/Disc Brake system using the ActiBrake system? I have not seen it as an approved controller for the Hyd/Disc system. Any input?
I currently use the Prodgy but have had the NC problem experienced with other users with this set up. The tech feedback from ActiBrake seem to think it is a low Voltage problem from the TV feed. ?????
I had no problem with the same wiring setup while I used the old electric brakes. Now that I've converted to Disc, the controller seem to go the sleep and indicates no connection. When I manually over ride it, it works OK.
The Hensley says it's compatible with Elect/Hyd systems but I'd like some user feedback if possible.
Fred Bartlett
30' S/O 70th Anniv. Excella, maple floors in Kitchen Galley, Hensley Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. back splash, LED Running Lights
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door and Bed Rug
fred bartlet is offline   Reply With Quote
Old 09-05-2007, 08:29 AM   #2
Wayne&Sam
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
I had the NC code a couple of times with my Prodigy on electric brakes. I found it to be corrosion on the wiring harness that plugs into the back of the Prodigy. I cleaned it up and have not had problems since.
Old 09-05-2007, 05:59 PM   #3
fred bartlet
Hensley doesn't appear on the ActiBrake approved list, so I'm looking into the Tekonsha P3. A third the price and on the list. ???
And my NC code is probably my 7 pin connector. It's the only old connection in the system, so I looking for a good cleaner for it.???? The ActiBrake was wired into the DC panel, in the coach, behind the sofa. Those connections are good and the pulg in to the pump is too new.????
Fred Bartlett
Old 09-06-2007, 07:50 PM   #4
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Fred, I was interested in that Hensley brake controller as well... although they list "proof" of the improved braking ability, they actually don't list any stopping distances between the Prodigy or the Hensley... they list "increased voltage to the brakes.." which is probably more indicative of them adding heavier gauge wire to the brakes than normal.
I had issues with my 7 way, put WD40 in it, worked like a charm!
Marc
Old 09-06-2007, 09:21 PM   #5
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Increased voltage? Wire size does not affect how much voltage a conductor can carry. It does affect current. Of course if the wire is too small the voltage will drop if current draw is too high. I would stick with a prodigy.
What Tow Vehicle do you have?
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
R&R Brake Controller Sundance Brakes & Brake Controllers 7 08-10-2007 06:06 PM
Brake controller? chaunceyboy Brakes & Brake Controllers 7 06-07-2007 11:43 PM
Hensley Brake Controller Worth the bucks? ldetsf Brakes & Brake Controllers 1 11-16-2006 01:21 PM
Which Brake controller Chitown AirStreamers Brakes & Brake Controllers 36 08-20-2005 01:15 PM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 07:47 AM
