Old 12-13-2007, 08:44 PM   #15
mrmossyone's Avatar
1975 Argosy 24
Collierville , Tennessee
Originally Posted by dwightdi
Sometimes you can rescue a drum by just pushing in a new stud if it is the kind that installs from inside the drum and has a flat head on it. Some of the people did not like the original lug bolts used on many of the trailers and installed just double ended studs from the outside of the drums. If you strip one of these out of the drum you will have to take the drum down to the local repair shop and have it taped out a litttle bigger with a special tap and then have what is called a "Helicoil" installed. It will cost a lot less than a new drum and all the problems entailed.
Are you saying I can get a double headed stud and screw it in from the outside of the drum and then put a lug nut on to the stud? Do you know where these can be purchased? Thanks.
Different strokes for different folks!
I never learned from a man who agreed with me.
Heinlein
mrmossyone is offline   Reply With Quote
Old 12-14-2007, 06:19 AM   #16
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Picture, please. That would clear up what you have and we can be certian that we are directing our answers to you for the correct setup you have.
Sounds like what you have is repairable, if not, there are many people on line replacing older axles and a drum will come up sooner or later.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-14-2007, 07:49 AM   #17
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
It sounds like you have the original wheel lug bolt type setup where the drums just have a tapped hole and the wheel nuts are really wheel bolts with a tapered shoulder on them. It also sounds like you have stripped one of your threads on the drum. Take the drum off and take it to a local shop and have it retapped and a Heilicoil installed. Many Napa and other general auto shops offer this service. If you want to do away with the wheel lug bolts and go to the stud and wheel nut type setup on all your wheels the local Napa or Autozone has all the necessary hardware.
Old 12-14-2007, 10:11 AM   #18
mrmossyone's Avatar
1975 Argosy 24
Thanks for the advice, I believe I will take Drum off and take to NAPA and have helicoil installed. I hope my NAPA store offers that service.
Those threads must of been on the verge of being stripped or already been stripped(even though I didn't notice any real loose ones when removing), because I was using a non-electric/air (i.e. me power) lug wrench and I by no means put a lot of force/torque when tightening the old school lug stud.
Heinlein
Old 12-15-2007, 09:17 AM   #19
mrmossyone's Avatar
1975 Argosy 24
Well so far,I have found no one to fix the drum. I have one more place to try and if it's a no go I will buy the helicoil and do it myself or at least attempt to. Any advice is appreciated.
Heinlein
Old 12-15-2007, 01:18 PM   #20
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Go to Jamie's Trailer Repair/Welding (901) 465-3004 620 Charlotte Dr, Oakland, TN. They should be able to drill and tap and install a Helicoil for you, probably for a nominal labor fee.
Old 12-15-2007, 04:29 PM   #21
mrmossyone's Avatar
1975 Argosy 24
Thanks, I will give them a call. Much appreciated.
Heinlein
Wheel bearings Allen H Axles 18 10-31-2007 04:12 PM
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Repacking Wheel Bearings Buttercup Axles 38 05-07-2005 08:57 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
