11-29-2011, 04:10 PM
1976 31' Sovereign
Missouri City
Help Tekonsha P3
I have the Tekonsha P3 like the one below and it has worked great for the past 3 years. I have Disc brakes. Today I hooked up the trailer and looking down at the screen where I would normally see O's light up the screen was blank. I checked the connection but still nothing. Looking at the screen from the side I can see a green back light so it would appear to have power but is not connecting. All of the other lights from the 7 pin connector work. Any thoughts
Don
Tekonsha brake controller - Bing Images
Don Hardman
1976 31' Sovereign
11-29-2011, 04:56 PM
Retired.
, At Large
Try unplugging it from the truck, and hold the manual control lever over for a few seconds. Plug it back in, and see if it works. A few have had this issue, and "draining" the power from it has resolved the problem.
Even if it doesn't work, you're not out anything, except a minute or two of time.
11-29-2011, 05:03 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
Don,
if your P3 screen is blank, it is possible that either there is no power to the P3, or that the P3 has failed.
when your TV is turned 'on' and the trailer 7-pin harness is disconnected, do you get the 'red screen' on the P3 saying "No Trailer Connection!"?
if no, then check for +12V on the black lead coming to the P3, and for a good ground on the white lead to the P3.
if yes, then try the diagnostics built into the P3. instructions can be found here - http://www.tekonsha.com/content/down...ion/N90195.pdf
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
11-29-2011, 05:18 PM
1976 31' Sovereign
Missouri City
I unplugged and then held the lever over for a few seconds. Plugged back up still nothing.
Now that it is dark outside the screen has a pale green color not the normal red screen. It does not show any of the error messages.
Don
Don Hardman
1976 31' Sovereign
11-29-2011, 05:19 PM
1976 31' Sovereign
Missouri City
Could it a fuse, somewhere in the Suburban, 2008.
Don Hardman
1976 31' Sovereign
1982 24' Airstream 240
Ventura
Our read out stopped working on our trip this summer
Our brake controller continued to control the brakes but the read out was missing.........we replaced it after spending a lot of money having someone trouble shoot it with a call to Tekonsha......
it cost $150 for a new one so in retrospect we should have just replaced it......I looked on the new box and it has a life time warranty.....so if we had known and had had time, we could have called them, got permission to fed ex to them and they would have sent out a new one......
So after the fact, I jumped through their return hoops and they sent me a replacement one.....so now we have a spare......
Or you could try to have a dealer try to return it if they are willing to try. paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
11-29-2011, 05:40 PM
1976 31' Sovereign
Missouri City
Thats interesting because I pulled the trailer home form storage and even though I was cautious, it towed the same as it does when when I know it is working. It sure felt like I had brakes. I will buy a new replacement unit and see what happens.
Don
Don Hardman
1976 31' Sovereign
11-29-2011, 06:06 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
Don
fwiw, the one and only time I called Tekonsha for support (for a bracket problem) they were perfectly gracious, helpful, and easy to do business with!
check the power going in & out of the P3, and if need be, I'd be exercising that limited lifetime warranty!
best,
Joseph & Gabrielle
11-29-2011, 06:12 PM
1981 31' Excella II
New Market
, Alabama
I thought these things had a lifetime warrantee or something.
Perry
11-29-2011, 06:43 PM
Ventura
Warranty
They do have a life time warranty but in order to get it replaced at no charge you have to contact them before buying another one....otherwise, you end up like us with a spare controller. We actually had time to have fed exed it to them and had them send another one but we were not aware of the life time warranty and they didn't volunteer that information. They would not refund our money that we spent on the second controller.....so we were stuck.
You can test to see if the controller is still activating your breaks....ours did and we drove from Rawlins, MT to Ft. Collins, CO without the readout working but it still stopped our trailer. We were afraid to continue on after that and just replaced the controller.....and the problem was a malfunction of the controller...not our wiring or anything esle....it was about 3 years old. paula
Paula & Ed
11-29-2011, 06:48 PM
Ventura
else
I meant to type "else"
Paula & Ed
11-30-2011, 05:10 PM
1976 31' Sovereign
Missouri City
Fixed it
I decided this morning to go ahead an get a new Tekonsha P3 since we are leaving town tomorrow, Thursday. So after driving to the RV parts palce in my area I decided I would unplug the unit and take it inside with me so I could make sure I had the right one. The Tekonsha P3 sits in a harness under the dask and can be removed by pressing a couple of clips and unplugging the wires at the back. I had never done that but it was fairly easy and then I had a thought. Reboot. So I plugged it back in and it came right on with the normal screen and then changed to the red screen indicating no trailer attached. Back in business. When I got home I connected the trailer and plugged in the connector and I have brakes.
Its been a long day getting ready for a few days out of town, so I think I will go Reboot myself and have a couple Jim Beam's.
Thank for the input guys. See you down the road.
Don
1976 31' Sovereign
Don Hardman
1976 31' Sovereign
11-30-2011, 05:43 PM
1981 31' Excella II
New Market
, Alabama
Have one for me. That is one of those 90% perspiration problems. You hack at it long enough and it fixes itself.
Perry
11-30-2011, 06:08 PM
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
I have the Tekonsha P3 like the one below and it has worked great for the past 3 years. I have Disc brakes. ...
I thought these controllers could not detect disk brake units--they need the low impedance of the electric brake magnets in order to show that a "trailer is connected." We're talking less than 5 ohms, here.
If this is so, then a low impedance load wired in parallel with the controller unit might be enough to simulate electric brakes.
Zep
11-30-2011, 06:14 PM
Ventura
The old "reboot" fix
Don
1976 31' Sovereign
That is great news......hav a fun trip.....now if only our new Denali with the built in brake controller would work for us by Friday......paula
Paula & Ed
11-30-2011, 06:44 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
"I decided I would unplug the unit.... and can be removed by pressing a couple of clips and unplugging the wires at the back.
hmm. sounds a lot like the suggestion Terry made in post #2! http://www.airforums.com/forums/f439...ml#post1077680
glad that you're back on the road.
Joseph & Gabrielle
11-30-2011, 06:50 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
Zep
hi, Zep,
Brake Controllers - Tekonsha
the P3 is hydraulic compatible, from the factory. no simulation or field mods necessary.... set it & go!
Joseph & Gabrielle
12-01-2011, 07:03 AM
1976 31' Sovereign
Missouri City
Originally Posted by jm2
I must have misunderstood Terry's suggestion, I thought he meant unplug the the 7 pin connector from the truck to the trailer. But maybe it just took a day for Terry's suggestion to sink into my brain. Thanks Terry
Don
Don Hardman
1976 31' Sovereign
