Old 11-30-2011, 06:14 PM   #15
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
The old "reboot" fix
Originally Posted by adonh View Post
I decided this morning to go ahead an get a new Tekonsha P3 since we are leaving town tomorrow, Thursday. So after driving to the RV parts palce in my area I decided I would unplug the unit and take it inside with me so I could make sure I had the right one. The Tekonsha P3 sits in a harness under the dask and can be removed by pressing a couple of clips and unplugging the wires at the back. I had never done that but it was fairly easy and then I had a thought. Reboot. So I plugged it back in and it came right on with the normal screen and then changed to the red screen indicating no trailer attached. Back in business. When I got home I connected the trailer and plugged in the connector and I have brakes.
Its been a long day getting ready for a few days out of town, so I think I will go Reboot myself and have a couple Jim Beam's.
Thank for the input guys. See you down the road.
Don
1976 31' Sovereign
That is great news......hav a fun trip.....now if only our new Denali with the built in brake controller would work for us by Friday......paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 11-30-2011, 06:44 PM   #16
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
"I decided I would unplug the unit.... and can be removed by pressing a couple of clips and unplugging the wires at the back.
hmm. sounds a lot like the suggestion Terry made in post #2! http://www.airforums.com/forums/f439...ml#post1077680
glad that you're back on the road.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 11-30-2011, 06:50 PM   #17
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
Originally Posted by Zeppelinium View Post
I thought these controllers could not detect disk brake units--they need the low impedance of the electric brake magnets in order to show that a "trailer is connected." We're talking less than 5 ohms, here.
If this is so, then a low impedance load wired in parallel with the controller unit might be enough to simulate electric brakes.
Zep
hi, Zep,
Brake Controllers - Tekonsha
the P3 is hydraulic compatible, from the factory. no simulation or field mods necessary.... set it & go!
Joseph & Gabrielle
Old 12-01-2011, 07:03 AM   #18
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I must have misunderstood Terry's suggestion, I thought he meant unplug the the 7 pin connector from the truck to the trailer. But maybe it just took a day for Terry's suggestion to sink into my brain. Thanks Terry
Don
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Argosy maiden voyage. shortcake All Argosy Trailers 18 09-29-2011 10:33 AM
Need advice on brake controllers. Flying-Steve Brakes & Brake Controllers 23 09-21-2011 02:47 PM
Our Road Trip 2011 in SteSpot SteSpot On The Road... 165 09-19-2011 03:28 PM
Tekonsha problem qc1500 Brakes & Brake Controllers 13 04-20-2011 04:00 AM
