Old 01-20-2009, 02:54 PM   #1
1978 24' Argosy 24
Tucson , Arizona
HELP, please Argosy 78' motorhome
Hey Folks,
I just started a full restoration on a 78' Argosy 24' motorhome. I have some guys working on the motor. We are having some trouble finding new front brake hoses???? I was just told by the chevy dealer that i need to find the code sticker to find out if the brakes are J-?? could be 7,8,9? I need this to go to Napa with to hopefully cross match some brake hoses. Any help would be greatly appreciated. It has a chevy 454, if that helps? Feel free to email me directly at smitty66@mac.com
Thanks in Advance,
Denise
smitty66@mac is offline   Reply With Quote
Old 01-20-2009, 07:19 PM   #2
Denise,
I'm not an expert on Chevy brakes but I came up with this info a while back. The first column doesn't specifically mention JB9 brakes but I pretty sure your 24' Argosy will have the JB9 brake system. Your motorhome will have front disc brakes and rear drum brakes. They should be able to measure your brake shoes and look at the list below to verify if JB9 is correct.
Hopefully this information will get you want you need.
JB1 BRAKE, MANUAL, DISC/DRUM, 4300 LBS
JB3 BRAKE, POWER, DISC/DRUM, 4600 LBS
JB5 BRAKE, POWER, DISC/DRUM, 6400 LBS
JB6 BRAKE, POWER, DISC, DRUM 7200 LBS
JB7 BRAKE, POWER, DISC, DRUM 8400 L85
JB8 8RAKE, POWER, DISC, DRUM 10000 LBS
Physical examination using the following specifications:
Engine Front Rotor Rr Drum/Rotor Power Booster Production #
Gas 11.86" x 1.28" 11 x 2" None JB1
Gas 11.86" x 1.28" 11 x 2" 9.5" Single Diaphragm JB3
Gas 11.86" x 1.28" 11.15" x 2.75" 9.5" x 8" Dual Diaphragm JB5
Gas 12.5" x 1.28" 11.15" x 2.75" 9.5" x 8" Dual Diaphragm JB6
Gas 12.5" x 1.28" 13" x 2.50" 9.5" x 8" Dual Diaphragm JB7
Gas & Diesel 12.5" x 1.53" 13" x 2.50" Hydro-boost JB8
Gas 14.25" x 1.53" 15" x 4" Hydro-boost JB9
Diesel 11.86" x 1.28" 11" x 2" Hydro-boost JD3
Diesel 11.86" x 1.28" 11.15" x 2.75" Hydro-boost JD5
Diesel 12.5" x 1.28" 11.15" x 2.75" Hydro-boost JD6
Diesel 12.5" x 1.28" 13" x 2.50" Hydro-boost JD7
Gas & Diesel 14.25" x 1.53" 13.75" x 1.53" Hydro-boost JF9 (4 wheel disc)
bkahler is online now   Reply With Quote
Old 01-20-2009, 07:29 PM   #3
1978 24' Argosy 24
Tucson , Arizona
thanks
Brad~
Thank you so much, you saved me so much time! I will take this to Napa, and I hopefully get what I need!
Thank You~
Denise
Old 01-21-2009, 06:25 AM   #4
Denise,
Be sure and post the part numbers to the forum once you're sure they fit correctly. That info will help other motorhome owners when it comes time to find replacement parts.
Good luck!
Old 01-21-2009, 10:25 PM   #5
1978 24' Argosy 24
Tucson , Arizona
Good idea~
brad,
Thanks I will do that. They come in on Monday, I am out of town for the week. But, I should find out if they fit, and I will post it.
Thanks again, you saved me a ton of time.
Denise
What is this thing on our Argosy Motorhome? bkahler Mechanics Corner - Engines, Transmission & More... 5 01-23-2009 06:20 PM
'77 Argosy motorhome mikecantrell Argosy Motorhomes 12 03-26-2008 07:19 PM
Argosy Motorhome Dashes. . . TheGanzman Argosy Motorhomes 5 10-26-2005 05:45 AM
Airconditioner location on a 78' Minuet ericandterry Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-26-2003 10:22 PM
