Old 08-01-2013, 10:33 AM   #1
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Help! Help! Positive Ground Tow Vehicle
Good Morniing America!
Can anyone please help?
I am fitting a Prodigy RF to an Avion. A very pretty trailer with a very pretty tow vehicle - a 51 Chevy pick-up
Only problem, the Chevy is POSITIVE EARTH!!!
I can't see how to reconcile the positive vehicle power going through the hitch AND powering the brakes??
Advice soon please! This is a live job on a countdown
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 08-01-2013, 10:46 AM   #2
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Just a guess...
Would separate wiring from the brakes to the controller work? In other words, disconnect the brake ground (earth) cable from the trailer frame, and connect it to a wire that runs to the negative side of the controller--wire size adequate for the current, of course.
I claim no experience whatsoever in doing this, so accept or reject this idea as you see fit.
Good luck!
Old 08-01-2013, 10:51 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Good luck!
If you do that, the power for the brake controller would have to be provided by a 12v-to-12v isolation transformer, which should allow you to reverse the polarity by hooking one side up backwards.
But that doesn't help with the lights, only the brakes.
Cats and ultraleather Airstream upholstery don't mix!
Old 08-01-2013, 10:57 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Light bulbs don't care if they are positive or negative earth.
Honestly, neither do the brake magnets.
Old 08-01-2013, 11:03 AM   #5
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I've never heard of an american vehicle with a positive ground. Our trucks were 6 volt negative ground until they went 12 volt around late 50's early 60's.
I had issues with installing a 8 track player ( I'm old) in my '58 MGA.
I had a separate battery to power it and mounted the case without grounding it to avoid this problem.
Unless you totally insulate the hitch from frame grounding there will be issues.
Somewhere in that '51's life it was converted 6/12 volt, +/- flipped.
"Chip Tank" is in Carson City Nv.
CDONA is offline   Reply With Quote
Old 08-01-2013, 11:28 AM   #6
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
What you need is a new voltage regulator for the pickup that is neg ground. Swap the wires for the amp gauge reverse the battery cables . Then polarize the reulator per instructions on the reg. And then you have a neg ground system.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 08-01-2013, 11:28 AM   #7
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
If the truck was converted to postive ground, may be easier to convert it back. I have 3 english sports cars and the 2 older ones are postive ground and the third is negative.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-01-2013, 11:37 AM   #8
1969 25' Tradewind
1983 34' Limited
Images: 85
Here is a link on how it is done Change positive ground to negative old tractor
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Old 08-01-2013, 12:03 PM   #9
1977 Argosy 24
Milltown , Wisconsin
As an old hot rodder, my advice is it's time to change the truck to negative ground. The only problem will be the radio if it has one.
ventport is offline   Reply With Quote
Old 08-01-2013, 01:50 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Hudsons were negative ground until they went to 12v in 1954 or 55.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 08-01-2013, 01:51 PM   #11
Moonstruck's Avatar
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
"Funny", my friend has a friend who is a hot rodder! I'm positive changing the polarity will solve it! The "stock" answer!
Sorry, couldn't resist it!
Silvertwinkie
Hampshire, UK
Old 11-05-2014, 07:07 PM   #12
1978 Argosy 24
MooreHaven , Florida
Fords were positive ground for many years,never saw a GM car with positive ground.That was common on english cars, to change it on them the fuel pump was a problem along with the fuel gauge and the radio and generator no simple job
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 11-11-2014, 02:53 PM   #13
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by oldiesel View Post
Fords were positive ground for many years,....
Ford Motor company was 6V and positive ground up to 1955. In 1956 all Ford Motor Company US products went to 12 V negative ground.
>>>>>>>>>>Action
Old 11-18-2014, 10:51 AM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
My 1999 Dodge Ram 2500 with Cummins Diesel came from the factory with a positive ground. It also has a factory-installed Bargman connector for the umbilical cord.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
