Old 01-08-2015, 10:29 AM   #71
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Ag&Au View Post
Wow!!! Hook the fuel tank of a positive ground truck directly to the fuel tank of a negative ground truck and you would have the perpetual motion machine that has eluded scientists since the dawn of man.
Ken
Knows this because two positive cats making a temporary connection to one negative cat can produce both heat and light for the trailer interior.
Old 01-08-2015, 12:01 PM   #72
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
True story.
Originally Posted by ROBERTSUNRUS View Post
Hi, this thread has had me thinking and that could be dangerous. Way back in the early 80's, while working as a quick service mechanic at a Ford dealer, I worked on a brand new Ford F-650 that was Positive ground. Anyone out there doubt this?
Originally Posted by GCinSC2 View Post
Action,
That makes perfect sense cause if it was hooked up backwards the engine would run backwards too and instead of filling the tank, you'd have to stop every couple hundred miles and suction out the diesel it would be generating instead of consuming! NOT!
Ok I'll go back to my CURRENT project.
Wow!!! Hook the fuel tank of a positive ground truck directly to the fuel tank of a negative ground truck and you would have an explosion the perpetual motion machine that has eluded scientists since the dawn of man.
Ken
Hi, I surprised that no-one doubted my story of the Ford F-650 with positive ground. So I will explain this story to you. One day they brought me a new Ford F-650 to repair the stop lights. Everything on this truck worked correctly, lights gauges starter motor, diesel engine and all. After checking wiring diagrams and tracing power with my test light, I found an inline diode to the brake lights. I tested the diode and it worked correctly and could only be plugged in one way. This was really strange. After further examining this truck, I noticed some Mickey Mouse battery cables. Come to find out; This truck was sent out for a stake bed and lift gate installation. While this truck was on their lot, the batteries were stolen, and their crew bought new batteries and aftermarket cables, and wired them up backwards. I was amazed that everything worked except the brake lights.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-08-2015, 12:39 PM   #73
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
My first truck was a 1961 Mack COE with positive ground, and believe me, it was hard to make anything work right. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-08-2015, 06:01 PM   #74
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ken
Ken,
I just had a flash cross my interior visual cortex, no wait its clearer now. A DeLorean towing a 30'. WOW!
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-08-2015, 06:40 PM   #75
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Ken,
Was the DeLorean positive ground?
Just checkin".
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 01-08-2015, 08:06 PM   #76
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
1951 Chevy truck ground
Maybe in Great Britain the Chevy trucks were positive ground, but the wiring diagram in the US suggest negative ground. I suspect before solid state this could potentially get reversed in some bizarre manner, but the wiring diagram shows negative ground:
http://chevy.oldcarmanualproject.com...df/51truck.pdf
So, maybe in some cases correcting a ground issue is important before hooking up a trailer. OK, a few years old, but the link to old cars electrical diagrams may bone helpful.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-08-2015, 09:11 PM   #77
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Really??? Those aren't Dodges. Here is the photo of the Cummins fired oil burner.
>>>>>>Action
Old 01-08-2015, 09:28 PM   #78
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Ken,
Now, that would be cool. The dual DeLorean setup would have the power to pull an infinite number of stainless steel airstreams of any length. Granted aluminum is cool, but stainless rules.
Ken
