Old 12-30-2014, 06:41 PM   #57
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I have no need for a wiring diagram. However I can think of one guy that might want it.
>>>>>>>>>Action
Action is online now   Reply With Quote
Old 01-05-2015, 08:48 PM   #58
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Action, do you want to meet for lunch on Wednesday? I'm leaving CG and heading to Vegas on Friday as I have to pick up my wife at the airport. Should be back in CG the last week of January.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 01-06-2015, 06:05 AM   #59
ottawa (greely) , Ontario
Talking
Hurry up guys and meet for lunch ,I've had 15 bags of popcorn and twenty cans of pop ,I'm running low on popcorn !
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-06-2015, 10:00 AM   #60
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Wednesday could work for me. I have a meeting in North Phoenix that ends about 11:30AM. If you are good with 12:30PM then let's set it for Wednesday.
After that the President will be in town for 24 hours and the roads will be jambed up a bit with security. I would rather not trravel during that event.
>>>>>>>>>>>>>>>>Action
Old 01-06-2015, 01:33 PM   #61
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Wednesday it is, then. I'll pm my cell number.
VE3JDZ
AIR 12148
Old 01-06-2015, 02:59 PM   #62
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I can't believe you don't want to post your cell phone number. You can trust us.
Ken
Old 01-06-2015, 08:03 PM   #63
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Ken
Really ???????
VE3JDZ
AIR 12148
Old 01-06-2015, 08:39 PM   #64
Ag&Au's Avatar
Really ???????
Sure, I won't send it to anyone except my pen pal in Nigeria. He's a prince with inside info on the lottery.
Old 01-06-2015, 09:10 PM   #65
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Positive ground.
Hi, this thread has had me thinking and that could be dangerous. Way back in the early 80's, while working as a quick service mechanic at a Ford dealer, I worked on a brand new Ford F-650 that was Positive ground. Anyone out there doubt this?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-06-2015, 09:54 PM   #66
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If anyone is in the area and wants to join along the venue has taken a twist from the British start. Famous Dave's in Chandler at 1PM. Famous Dave's | Famous Dave's
For those that are playing at home stay tuned to As the Electron Travels.
>>>>>>>>>>Action
Old 01-08-2015, 07:50 AM   #67
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Aaaaah the result!!!
The day was very nice and sunny.
A great day to be on the road.
The BBQ was tasty.
Learned about camp sites south of Phoenix.
And the 1999 US truck production of vehicles is consistant in the mounting of battery cables with every other vehicle of that year. And years since. For this dual battery diesel powered 3/4 ton TV, the black cable on the driver's side battery was bolted to the front of the Cummins.
>>>>>>>>>>Action
Old 01-08-2015, 09:13 AM   #68
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Action,
That makes perfect sense cause if it was hooked up backwards the engine would run backwards too and instead of filling the tank, you'd have to stop every couple hundred miles and suction out the diesel it would be generating instead of consuming!
Ok I'll go back to my CURRENT project.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 01-08-2015, 09:49 AM   #69
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The BBQ was tasty.
>>>>>>>>>>Action
And the peripherals, such as lights, fuel pump etc have a switched negative and an active positive which is controlled via a 5-volt system from the computer, hence it's misnomered as a "positive ground". This switched negative system results in less current running under the dash.
The lunch, BTW was most enjoyable.
VE3JDZ
AIR 12148
Old 01-08-2015, 10:18 AM   #70
Ag&Au's Avatar
Originally Posted by GCinSC2 View Post
Action,
Wow!!! Hook the fuel tank of a positive ground truck directly to the fuel tank of a negative ground truck and you would have the perpetual motion machine that has eluded scientists since the dawn of man.
Ken
