Old 11-18-2014, 11:22 AM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by blkmagikca View Post
My 1999 Dodge Ram 2500 with Cummins Diesel came from the factory with a positive ground.
Care to check this or prove somehow?
Wishing the OP luck, just challenging the Dodge statement.
My 1997 and 2005 Dodge Cummins each have two batteries.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-18-2014, 11:44 AM   #16
1964 26' Overlander
Myrtle Beach , South Carolina
Wasn't going to say anything because I didn't know if it might be a canadian thing but I second the Ram observation. Positive ground????
streamdreamn is offline   Reply With Quote
Old 11-18-2014, 12:03 PM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Really old thread, but really there isn't any issue when switching a vehicle from positive to negative ground.
Gauges don't care, starter doesn't care, most other electric motors don't care, lights don't care...
Therefore the easiest solution is to convert the vehicle to negative ground and 12volts at the same time.
Going to 12 volts isn't a challenge either, just a few more simple fixes.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-18-2014, 12:25 PM   #18
GCinSC2's Avatar
Disagree.
Modern vehicles are packed with electronics and computers.
S/OS #001
Old 11-18-2014, 12:48 PM   #19
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
By the mid to late 1950s all US built vehicles were negative ground. Most of the vehicles built in the UK (no matter the builder like Ford of England) were postive ground (earth) until the late 1960s with Austin holding out to 1971. Many of these have been coverted to negative ground.
Since about 1968 when electronic devices (mostly ignition products) were introduced on US built automobiles to start to comply with GVT regulation, the ground side of the system becomes very important as electronic devices require a clean and strong electrical signal from both sides. Many vehicles that had early electronic devices also had a new additional ground wire instead of relying on the engine block or frame as a good source of ground. This was to get a clean ground signal for the electronic device.
>>>>>>>>>>>>>Action
Old 11-18-2014, 02:18 PM   #20
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Help! Help! Positive Ground Tow Vehicle
But I cant name a single car that uses any kind of computer that left the factory with a positive ground system.
As stated above, the last American vehicle to have positive ground lest the factory in 55.
I happen to own one of these cars that I converted to 12 volts and negative ground in just a little time, for not a lot of money.
http://i245.photobucket.com/albums/g...Sonoma-1-1.jpg
As an aside, pointless trivia, there are many who contend that positive ground is superior to negative ground in the transmission of power throughout a vehicle.
Old 11-18-2014, 02:32 PM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Yes and no... I switched several British Sports cars from positive to negative ground. Tachometers had to be reconfigured and it didn't always work. I had one electric fuel pump that didn't take kindly to being told to run on negative ground.
Supposedly you got less corrosion with positive ground vehicles because of it was correct for the flow of electrons in a DC system.
Aaron
WBCCI #XXXX AIR #2495
Old 11-18-2014, 04:19 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Some tachs might be a problem, fuel pumps maybe, both depending on their configuration.
In any case, back to the original post, if I had to tow a trailer, the most simple solution would be to convert the tow vehicle to 12V negative ground.
My Lincoln required 12 volt light bulbs, a 12 volt generator, a gage resistor from a Mustang, and a 12 volt to six volt converter to run my stock radio. The radio now runs negative ground with no ill effects.
Old 11-19-2014, 06:13 PM   #23
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I was told that my 1999 Dodge 2500 with 24-valve Cummins diesel has a positive ground system by the lead diesel mechanic at Southbank Dodge in Ottawa where I service my truck.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-19-2014, 06:21 PM   #24
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by Jim Foster View Post
Hudsons were negative ground until they went to 12v in 1954 or 55.
This should have read Hudsons were positive ground.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-15-2014, 06:31 PM   #25
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Negative ground
Old 12-15-2014, 09:23 PM   #26
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Model T's were neg. ground, the A's on up were positive ground until the early 50's.My 07 dodge with 2 batteries is neg ground, my 92 ford 7.3 made in Canada is negative ground...
Old 12-16-2014, 07:50 PM   #27
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Originally Posted by slowmover View Post
Negative ground
Regrettably, you are incorrect. The 1999 Dodge Ram 2500 Diesel has a positive ground. FYI, see https://www.google.com/search?q=1999...A&ved=0CD8QsAQ
VE3JDZ
AIR 12148
Old 12-16-2014, 08:26 PM   #28
r carl's Avatar
Lin , Ne
Google isn't 100% correct.
r carl is online now   Reply With Quote
