08-01-2013, 10:33 AM
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English
, Hampshire
Help! Help! Positive Ground Tow Vehicle
Good Morniing America!
Can anyone please help?
I am fitting a Prodigy RF to an Avion. A very pretty trailer with a very pretty tow vehicle - a 51 Chevy pick-up
Only problem, the Chevy is POSITIVE EARTH!!!
I can't see how to reconcile the positive vehicle power going through the hitch AND powering the brakes??
Advice soon please! This is a live job on a countdown
08-01-2013, 10:46 AM
1966 22' Safari
Hilltop Lakes
Just a guess...
Would separate wiring from the brakes to the controller work? In other words, disconnect the brake ground (earth) cable from the trailer frame, and connect it to a wire that runs to the negative side of the controller--wire size adequate for the current, of course.
I claim no experience whatsoever in doing this, so accept or reject this idea as you see fit.
Good luck!
08-01-2013, 10:51 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Good luck!
If you do that, the power for the brake controller would have to be provided by a 12v-to-12v isolation transformer, which should allow you to reverse the polarity by hooking one side up backwards.
But that doesn't help with the lights, only the brakes.
08-01-2013, 10:57 AM
Retired.
, At Large
Light bulbs don't care if they are positive or negative earth.
Honestly, neither do the brake magnets.
08-01-2013, 11:03 AM
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
I've never heard of an american vehicle with a positive ground. Our trucks were 6 volt negative ground until they went 12 volt around late 50's early 60's.
I had issues with installing a 8 track player ( I'm old) in my '58 MGA.
I had a separate battery to power it and mounted the case without grounding it to avoid this problem.
Unless you totally insulate the hitch from frame grounding there will be issues.
Somewhere in that '51's life it was converted 6/12 volt, +/- flipped.
"Chip Tank" is in Westwood Ca.
08-01-2013, 11:28 AM
2008 27' Classic FB
1959 22' Flying Cloud
fairview
, New Mexico
What you need is a new voltage regulator for the pickup that is neg ground. Swap the wires for the amp gauge reverse the battery cables . Then polarize the reulator per instructions on the reg. And then you have a neg ground system.
Avion C11
1959 Flying Cloud 1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
2012 28' International
New Orleans
, Louisiana
If the truck was converted to postive ground, may be easier to convert it back. I have 3 english sports cars and the 2 older ones are postive ground and the third is negative.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
08-01-2013, 11:37 AM
2008 27' Classic FB
fairview
, New Mexico
Avion C11
1973 Safari
1983 34 ft Limited
08-01-2013, 12:03 PM
1977 Argosy 24
Milltown
, Wisconsin
As an old hot rodder, my advice is it's time to change the truck to negative ground. The only problem will be the radio if it has one.
08-01-2013, 01:50 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Hudsons were negative ground until they went to 12v in 1954 or 55.
08-01-2013, 01:51 PM
1986 31' Sovereign
1975 25' Tradewind
1967 17' Caravel
Sherfield English
, Hampshire
"Funny", my friend has a friend who is a hot rodder! I'm positive changing the polarity will solve it! The "stock" answer!
Sorry, couldn't resist it!
11-05-2014, 07:07 PM
1978 Argosy 24
MooreHaven
Fords were positive ground for many years,never saw a GM car with positive ground.That was common on english cars, to change it on them the fuel pump was a problem along with the fuel gauge and the radio and generator no simple job
This is only temporary unless it works! Red Green
11-11-2014, 02:53 PM
Moderator dude
1966 26' Overlander
Phoenix
Originally Posted by oldiesel
Fords were positive ground for many years,....
Ford Motor company was 6V and positive ground up to 1955. In 1956 all Ford Motor Company US products went to 12 V negative ground.
>>>>>>>>>>Action
11-18-2014, 10:51 AM
1987 32' Excella
Nepean
, Ontario
My 1999 Dodge Ram 2500 with Cummins Diesel came from the factory with a positive ground. It also has a factory-installed Bargman connector for the umbilical cord.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
11-18-2014, 11:22 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Care to check this or prove somehow?
Wishing the OP luck, just challenging the Dodge statement.
My 1997 and 2005 Dodge Cummins each have two batteries.
11-18-2014, 11:44 AM
CHIEF THINGAMAJIG FIXER
1964 26' Overlander
bugtussel
, South Carolina
Wasn't going to say anything because I didn't know if it might be a canadian thing but I second the Ram observation. Positive ground????
11-18-2014, 12:03 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Really old thread, but really there isn't any issue when switching a vehicle from positive to negative ground.
Gauges don't care, starter doesn't care, most other electric motors don't care, lights don't care...
Therefore the easiest solution is to convert the vehicle to negative ground and 12volts at the same time.
Going to 12 volts isn't a challenge either, just a few more simple fixes.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
11-18-2014, 12:25 PM
Somewhere
, South Carolina
Disagree.
Modern vehicles are packed with electronics and computers.
11-18-2014, 12:48 PM
Moderator dude
1966 26' Overlander
Phoenix
By the mid to late 1950s all US built vehicles were negative ground. Most of the vehicles built in the UK (no matter the builder like Ford of England) were postive ground (earth) until the late 1960s with Austin holding out to 1971. Many of these have been coverted to negative ground.
Since about 1968 when electronic devices (mostly ignition products) were introduced on US built automobiles to start to comply with GVT regulation, the ground side of the system becomes very important as electronic devices require a clean and strong electrical signal from both sides. Many vehicles that had early electronic devices also had a new additional ground wire instead of relying on the engine block or frame as a good source of ground. This was to get a clean ground signal for the electronic device.
>>>>>>>>>>>>>Action
11-18-2014, 02:18 PM
1972 31' Sovereign
Benton
, Arkansas
But I cant name a single car that uses any kind of computer that left the factory with a positive ground system.
As stated above, the last American vehicle to have positive ground lest the factory in 55.
I happen to own one of these cars that I converted to 12 volts and negative ground in just a little time, for not a lot of money.
http://i245.photobucket.com/albums/g...Sonoma-1-1.jpg
As an aside, pointless trivia, there are many who contend that positive ground is superior to negative ground in the transmission of power throughout a vehicle.
