Old 04-12-2010, 04:57 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Help!!! finding spring for drum brakes
Please help,
I need to find this spring or a hardware kit for my old drums on a 1966 Globetrotter.
I have been to 6 different auto parts stores and brake places and no one can find a match.
Does any one know what hardware kit would work on my original back plates.
Your help is appreciated,
Bruce
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 04-12-2010, 05:38 PM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Try Inland RV in California or OutDoors Mart I think it is. There is a possiblity that the parts are obsolete. I know my 77 had old style magnuts and I did not take the chance on finding parts . The axles were shot anyway so I just got all new.EVERYTHING. You may just get away with changing the backing plates and getting all new brakes.
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-12-2010, 06:52 PM   #3
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
It's been a very long time, but. Doubtfull you'll find one in a modern parts store. Most cars drum brakes had one end much longer than the other on the lower return spring after auto adjusters came out. Heavy duty 3/4 ton trucks up to 1 1/2 ton often had springs with equil length, at least into the '80s. You may want to check a light truck shop and look for the oldist guy there. In a pinch you can buy 2 of the modern ones and clip the long end off one to make a hook and eye extention for the other. I've also seen 8 penny nails bent and used to extend!
putback is offline   Reply With Quote
Old 04-12-2010, 07:47 PM   #4
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Hi there, Go get yourself two new backing plate assemblies. You get new magnets, new brakes and new hardware all in one shot. Don't forget to take the old one with you when you go get the new ones. It helps a great deal for them to see exactly what you have. Try an RV shop or comercial trailer shop. Forget about going to an auto parts store. They won't have what you need.
Good Luck !
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 04-12-2010, 08:17 PM   #5
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Bruce, go to a place that works on brakes....they should have springs from old brake sets laying all over every where. Bill
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 04-13-2010, 10:29 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
In a perfect world you would replace the entire backing plate as a fully loaded assembly.
Given that go to a trailer store, like this one.
Welcome
As worst I am sure there is one in GR.
>>>>>>>>>>>Action
Old 04-13-2010, 10:39 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
That appears to be a light spring that pushes pushes the magnet against the plate in the drum.
If you have not found an answer by Sunday PM me and i may be able to come up with a couple used ones. Won't be home to look until Sunday.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-15-2010, 08:52 PM   #8
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
Found some for my '78 Sovereign at a local trailer (not camper) repair shop.
Birdwell57 is offline   Reply With Quote
Old 04-15-2010, 09:55 PM   #9
Originally Posted by bmklawt View Post
Please help,
Bruce
Bruce.
You need to ask for a "brake adjuster kit".
That kit includes the adjuster and spring.
But, they break because of being over heated way to many times. Normally, all of them are replaced.
You will be money ahead, and leave headaches behind, if you replace the complete backing plates, that have the oval magnets, either in the standard types or the new "self adjusting" types brakes, as some of the other parts are no longer available.
Old 04-15-2010, 09:56 PM   #10
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
That very spring stranded our 66 overlander when it broke and dropped the adjuster and it jammed up the wheel. I was trading the trailer so didn't want to invest a lot on upgrades. I was able to find new adjusters, and all new springs at a local RV place that had been around awhile. You're looking for the adjuster spring and I was unsuccessful finding one at other places like online trailer supplies or local shops until the RV place because that old style is not made anymore. If you got an old shop check with them, but if they have them I'd replace all the springs, if one is failing the rest are likely not far behind.
Might check the condition of your axle anyway, if it needs replacing then you'd end up with new backing plates and brakes anyway.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 04-16-2010, 05:45 AM   #11
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Adjuster spring
If you decide to go with new backing plates, shoes, adjusters and oval magnets, then order the complete assembly on-line. I just had all 4 wheels renewed with new backing plates and the works at a local brake place and ......it was expensive!! Charge me $97.00 each for the assemblies, with labor and tax it was $617.00!!
Here is a place you can get them for $50 - $60 with "free" shipping: Trailer Brakes Brake Assemblies 12 x 2 Inch | etrailer.com
Old 04-19-2010, 09:59 AM   #12
Arrowstream's Avatar
Columbia , South Carolina
I just replaced the backing plates on a 1970 Nomad with Dexter 4-lug, 10 x 2 1/4 nev-r adjust brakes. They cost me $84+shipping. The hardest part was finding new 7/16 x 20 nuts.
Arrowstream is offline   Reply With Quote
Old 04-21-2010, 08:26 PM   #13
1978 29' Ambassador
Selmer , Tennessee
Adjuster spring for drum brakes
go to www.redline-parts.com
trailer repair parts #BP08-070 the ADJ SPRING. Or you can get them from:
Mid South RV, 1016 Hwy 45 South, Selmer TN, 38375
Phone #1-731-645-9640 ask for Rick Phillips. costs around $5.00 each. They are available for the 10" or 12" drum.
Just put some on our 78 Ambassador today. DH says they are a little different than the originals, but they work fine!
PaulaJo
PaulaJo is offline   Reply With Quote
Old 04-22-2010, 06:24 AM   #14
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Thanks everyone,
I found exact replacements at Bell tire, they found a few in there parts pile.
Bruce
disc vs drum brakes Brad Hunt Brakes & Brake Controllers 71 07-23-2008 02:23 PM
Disc vs Drum Brakes? Thrift Brakes & Brake Controllers 39 08-11-2007 12:19 PM
Trailer Brakes - Drum to disk upgrade safarinight Brakes & Brake Controllers 26 07-17-2007 05:32 PM
Need easy way to take brake drum off..>> Mrcrowley Brakes & Brake Controllers 18 05-23-2006 08:44 PM
