Old 09-14-2007, 10:14 PM   #71
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by sequoiacoast
TV receptor (I hope I am being clear) read about 9 volts at the brake pin & ground. The trailer umbilical read nothing at the same corresponding points, while not connected to the TV.
I did check the charge wire while the trailer and TV were connected and the TV was running- I saw no voltage. That's what is making me wonder if it's a fuse or if the wiring is not right.
If that is a fact, then you have more than one problem.
Uwe
www.area63productions.com
Old 09-17-2007, 10:36 AM   #72
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
Unbelievable!!
I have a 2004 Chevy 2500HD duramax. I had my brake controller (old one) installed by the dealership. Because of an alert I read from azflycaster on another thread, I decided to track down where the fuse is for the charge line in my truck. Interstingly I found it, and it is a fake. It is something they should have put in; it doesn't come installed- it's taped to the wiring harness... that they used! (In picture: Fuse is the Red "B+ position (Stud 1) top left-hand corner)
Off to the auto parts store...
BTW without a fully charged trailer battery.. would the Actibrake not function properly? That's what it says in the manual, but I don't know if the actions I've had would be a result of that?!? At any rate my trust factor in the "pros" is what it is, and my signature is what it is because of that. That is why I'm droning on and on in this thread. I need to know my own system- the people I throw money at don't seem to care or know *%#*!
Tanya
"If you want something done right, do it yourself!"
sequoiacoast is offline   Reply With Quote
Old 09-17-2007, 10:48 AM   #73
1968 24' Tradewind
Eureka , California
Uh... Eureka...!
My coffee is sloshing around and I am just starting to think clearly. If there is no fuse for my charge line, which is the same thing as the 12v + I need to operate the Actibrake... how in the world is the pump functioning? Is it using the power from the brake-away battery through the brake-away wiring?
Tanya
Old 09-17-2007, 10:53 AM   #74
richinny's Avatar
2011 34' Classic
do you have a seperate break away battery? if it uses the trailer battery i think the brakes would work until the battery was too weak to operate it. then possibly, the brakes would lock to alert you of a hazardous condition?
Ricky
Old 09-17-2007, 10:58 AM   #75
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
This is getting more fascinating by the minute, Tanya.
OK, let's summarize:
12V at charge wire connection at fuse box? It should be connected to an external stud outside the fuse box, fused by a 20 or30A fuse, maybe 40A, even. yes/no?
12V at trailer connector TV side? You should read 12or13v there from the charge pin to ground.yes/no?
12V at hot side of the breakaway switch? Try this with the tow vehicle disconnected, record your findings,and then connect it, run it, and again record your findings. Assuming that the coach battery is fully charged.Yes/no?
12V at battery cable positive terminal, when disconnected from the battery?
Battery voltage with battery disconnected?
leva the negative cable on, and check from positive to negative battery post, and ten from positive battery post to bare aluminum somewhere, like the wall or a rivet etc. see what we got.
Uwe
Old 09-17-2007, 11:05 AM   #76
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
The positive (power supply, 12V+) of the actibrake should be wired to the coach battery. It will function as long as the battery has a sufficient charge, tow vehicle or not. This has nothing to do with the breakaway switch, only that the breakaway switch is also wired to 12V, applying power to the actibrake's breakaway circuit in case of emergency.
The breakaway switch is NOT the main power supply. It will supply power to the control circuit of the actibrake, not the pump itself. It does get it's power from the coach battery, though.
Like this:
Normal operation:
Breakaway switch inactive, battery power to the actibrake from the coach battery, control voltage to the actibrake from the brake controller. Coach battery is supposed to be replenished constantly via the truck's charge line.
Emergency operation.
Trailer hurdling down the road aimlessly, tow vehicle going elsewhere. Pin is pulled from the breakaway switch. 12V applied to the Control Circuit, while 12V is also supplied to the pump circuit. Since the 12V is similar to full brake input from the brake controller, actibrake thinks "full power stop" and applies brakes very hard, thereby cancelling trailer's desire to smash into each and any object in it's way. Hopefully sooner than later.
Uwe
Old 09-17-2007, 01:49 PM   #77
1968 24' Tradewind
Eureka , California
My afternoon suddenly got busy with kid stuff, so I'll have to preform my test later.
I got the fuse for the truck and will see if that solves my charge issue.
Here is a scanned copy of the AB install- hope it is readable.
The manual shows how I am powering the Actibrake- through the TV, via the connector 12v+. The connection of the AB to the trailer battery is through the brake-away (brown wire).
My crack-pot thoughts:
My brake-away switch hot side is connected to a separate wire (not the charge line) that runs to the "Central control" fuse panel in the galley. The charge line to the coach battery also connects here with a 40a fuse.
The neutral side is connected to the Actibrake. The AB is connected to the coach battery. The AB needs power through the black wire, not the brown, but my truck was not supplying that power.
Could this have been the power to the pump if the 12v line wasn't functioning from the TV?
**Picture of "central control" 12v fuse panel. The colored notes on top of the manual schematic are how it actually is. The "spare fuse" is actually where the charge line is located and using a 40a fuse.
Name:	scan AB install.jpg
ID:	45532   Click image for larger version
Name:	12 volt panel as-is.jpg
Tanya
Old 09-17-2007, 03:17 PM   #78
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
It all looks good, Tanya. You should now have a functioning connection between the truck battery ( truck charging system when it is running)and the trailer's 12V system, meaning that the truck supplies 12V power to the trailer while you are driving. It therefore supplies steady power to the actibrake unit, as well as the trailer battery.
It might well be that most or all of your problems might have been related to the lack of charge from the tow vehicle.
Uwe
Old 09-17-2007, 10:48 PM   #79
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Confusing the confused
Hi, simply put; Because GM dosen't install the charge fuse in the fuse panel to actuate the trailer charge wire to the seven pin connector, the Actibrake system has no power to work. Hence problems. For you, I hope this is the answer to this mistery. And step #5 on instructions is explaining the need for the 12 volts, from the tow vehicle, to work the Actibrake and the blue wire to monitor the signal from your brake controller.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-18-2007, 09:58 AM   #80
1968 24' Tradewind
Eureka , California
Well, my lesson is: Never ASSume.
Dealership installs a factory harness with a fuse taped to it. Maybe the fuse is still taped to it .
Even though I put in a new umbilical and changed the incorrect position of the charge line (mixed up with reverse lights) it still never worked.
Camping at hook-up sites has left me without the opportunity to drain the battery and thus figure it out sooner- need to get back to roughing it .
Voltmeters are fun and easy to use once you go down to the store to buy a new one and figure out how to use and read the one you have (still don't get the ohms thing).
The charge line is now in effect.
Tanya
Old 09-18-2007, 10:09 AM   #81
_
so all is working now and correctly?
this issue of the chevrolets having a dummy fuse has been discussed multiple times...
but still regularly bites folks who plan on towing.
it seems like they have created this nagging issue by leaving out a nickel fuse.
happy travels!
2air'
Old 09-18-2007, 10:13 AM   #82
1968 24' Tradewind
Eureka , California
Well the 12v line is active and I guess I won't know if all is well until I take that trip up North and the brakes behave the WHOLE way! They always worked like they should... right up until they didn't (randomly).
Tanya
Old 09-18-2007, 10:54 AM   #83
richinny's Avatar
2011 34' Classic
please refresh my memory. who installed the brake controller in the truck?
Ricky
Old 09-18-2007, 12:40 PM   #84
1968 24' Tradewind
Eureka , California
The dealership where I bought the truck.
Tanya
Brakes working correctly? Dbraw Electrical - Systems, Generators, Batteries & Solar 8 02-27-2007 07:16 AM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
