Old 01-30-2007, 01:47 PM   #1
1958 18' "Footer"
Sebastopol , California
Help! Custom or stock wheels?
I need a little help fellow A/S owners. I have a 58 Travler with split rims and bias tires and they have to go ! I'm trying to find some stock steel wheels (nonslit rim). The trouble I'm having is with back spacing. The current wheels and tires are wheel 15x7 with 0 back spacing and a 7.00 x 15 tire. With this set up I only have 1/2" clearance at the inner fender well and 2 1/2" to the outer. This is measured at the widest (sidewall) part of the tire. There are signs of rubbing on the inner fender. All I can find for wheels are 15x7 with 0 backspace, I'd like to add 1/2" positive backspacing to give alittle more room inside. I'm also afraid that radial tires will be wider at the side wall than the bia ply. Has anyone dealt with this problem. Many wheel shops have said I'm going to have to have that wheel made. I need to get this squared away so I can tow my A/S!!!! Oh yea, will adding positive BS add to much stress to the bearing and/or spindle?
60's Iron is offline   Reply With Quote
Old 01-30-2007, 01:52 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Nomenclature
Originally Posted by 60's Iron
I need a little help fellow A/S owners... The trouble I'm having is with back spacing...
Do you mean offset?
Tom
Old 01-30-2007, 01:54 PM   #3
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
spacers are available to place between the wheel and the brake drum. just make sure your studs are long enough. I can't believe you can not find the right wheel- keep looking. I had to put 1/4" spacers on my Avalon when I went to a wider radial. The spacers work.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 01-30-2007, 02:02 PM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Iron-
Yes, get rid of those splits! What I would do is get myself a pair on nice black rims, Baby moons and some white wall tires. Now that would be cool!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-30-2007, 04:25 PM   #5
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Wheels
WWW.trailer-parts-forless.com
Gunnyusmc is offline   Reply With Quote
Old 01-30-2007, 04:27 PM   #6
1958 18' "Footer"
My Mistake
Yes offset not back spacing. Am I bad?
Old 01-30-2007, 05:02 PM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
This site may help too.
Wheel Vintiques | Welcome
>>>>>>>>>>>>>>>>>>>Action
Old 01-30-2007, 06:56 PM   #8
1960 24' Tradewind
santa barbara , California
Hello 60s Iron,
Radials would rub with your current 0 offset wheel most likely.Stockton
wheel in Sacramento Ca can build you new wheels or probably have the ones you need .They will do whatever backspacing you need .Back spacing or offset ,either term is used in the wheel industry .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 01-30-2007, 07:01 PM   #9
1984 31' Excella
Norfolk , Virginia
Images: 11
Help, Custom or stock wheels
This is a pretty good website for the explination of wheel dimentions:
https://www.rsracing.com/tech-wheel.html#fitting
Good luck
Beginner
Beginner is offline   Reply With Quote
Airstream Wheels JAG Wheels, Hubs & Bearings 10 06-01-2006 08:54 PM
Custom Designing Cat Cabinets, Counter Tops & Furnishings 0 07-22-2002 02:09 AM
Airstream steel wheels davidz71 Our Community 5 05-23-2002 07:50 AM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
