Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-21-2006, 07:03 PM   #1
DOCTOR-MX
Profile:  Currently Looking...
Celaya, Gto. , MEXICO
Question help brakes
I have a question I put a DrawTite 2-4 Brake Electronic Brake Controller - Time Delayed and the trailer brakes doesn’t work,( I own an old travel trailer ´80, Bravo (brand), made in Ciudad Juarez Mex. about 29-30f. and 6000 lbs, two axel). I checked all wiring (7 pin connector), and every thing works fine, but no brakes. I have current in the connector (blue wire) and following the wire there are continuity till the brakes, but after the magnet also I have power (with a light tester), is that correct?, because I thought one wire goes to ground and the other comes with de current, wrigth?. With the other truck (82 Dodge 360) I used a Tekonsha hydraulic type, and the brakes works fine, now I change it for a 96 F250 PSD and I have the problem. I have read that unless you go more than 10-15 miles/hour (maybe this weekend I’ll try but in the meantime) , it will work, is that correct? or what is wrong? How can I test the electro-magnets and to know if they are fried?
Thanks for all the inputs.
DOCTOR-MX is offline   Reply With Quote
Old 08-21-2006, 07:24 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Put 12V power straight to the magnets. You should hear a clunk and/or a hum from inside the brake drum.
Also, make sure your negative side is solid ( ground)
Uwe
Old 08-21-2006, 07:59 PM   #3
DOCTOR-MX
Thumbs up
Uwe, thanks for your answer, I already put 12V straight to the magnets and not any noise and with the axe in block, the wheel spins freely. I´m goning to check the ground. any other idea?
thanks again
Old 08-21-2006, 08:22 PM   #4
uwe
418
uwe's Avatar
Images: 40
thanks again
Time to pull the drums and inspect the wiring and magnets. You might try and read resistance for each individual magnet, and make sure you don't have a wiring break somewhere, or a corroded ground terminal, hard to say without actually being there....
Remember, it takes hot AND ground to make things work.
Uwe
Old 08-23-2006, 05:03 PM   #5
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
Dr. Mx. Can you pull the drum and post some pictures of the brakes, wires etc?
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 08-25-2006, 07:28 PM   #6
DOCTOR-MX
Arrow pics
I will, but first I´m going to check the groun, but now it´s rainning a lot here in my town, so I have to wait to better weather. Thanks anyway.
Old 08-30-2006, 05:59 PM   #7
DOCTOR-MX
Question
Another questions: I´m planning to work tomorrow with my trailer brakes, (if it doesn´t rain)
1.- The magnets has 2 wires, is one of them specific for hot (12V) and the other for ground, or it doesn´t matter which one you use? are there any mark (+ or -) on the magnet or an specific position (central or periferic or something like that)??
2.- The magnets have to show continuity between the wires with the tester?
Thnx for the inputs
Old 08-30-2006, 06:18 PM   #8
uwe
418
uwe's Avatar
Images: 40
The wires coming off the magnets can be connected either way, as long as there is no short. Not speficic to + or -
Thnx for the inputs
The magnet coil must show resistance. I do not know the actual value off hand, but there should be some Ohm reading on your meter, neither indefinite, nor "0".
Uwe
Old 09-01-2006, 07:43 PM   #9
DOCTOR-MX
Thumbs up good news.
First thanks again uwe.
I worked all yesterday morning checking the wires under the TT, and I founded that the problem was the ground wire, in some part was interrupted. So I put a new one and every thing is working OK. I can hear the "buzz" of the magnets and the wheels blocks in both sides when foot or manual break action.
So in resume, as several of you mentioned and which I founded in the forum searching for electric brakes, the main problem is GROUND.
Maybe next week I´ll try it on the street.
Thank a lot to all of you and the wonderful AS forums.
My best regards. JOSE A.
Old 09-01-2006, 07:46 PM   #10
DOCTOR-MX
I read that the resistance is 3.2 ohms.of the magnets.
Brakes working correctly? Dbraw Electrical - Systems, Generators, Batteries & Solar 8 02-27-2007 08:16 AM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
