Old 07-24-2004, 08:13 PM   #1
Hadco Brake Drum
Hello:
Could anybody help me locate a Hadco Eng. Co. LA 10" brake drum #440? The bearing numbers are: outside bearing number: tyson M12649; inside bearing number: timken LM48548? I believe these drums were on early Airstream and Aristocrat trailers. Thank you in advance.
rfcjr is offline   Reply With Quote
Old 07-25-2004, 05:18 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Have you tried the source, Hadco Engineering, Inc.....
Since 1945 Hadco has produced a full line of axle and brake assemblies and components for thousands of light and heavy-duty vehicle applications.
Address
POB 18713
Anaheim
CA
92817
United States
http://www.hadcoengineering.com/
Telephone, fax and web
Tel: +1909 278 1952
Fax: +1909 278 1954
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 09-22-2011, 09:03 PM   #3
El Dorado , California
Hadco 440
Call Hadco Engineering at 951-278-1952, the 440 is part number 524007and the inner plate is part number 520068.
Priddin is offline   Reply With Quote
Old 10-22-2011, 09:19 PM   #4
Vintage Kin
Fort Worth , Texas
This axle supplier was used on Silver Streak right up until the 1980's. I emailed them once on mine, but had no response (was looking for shock absorber specifications). The PO had already converted the brakes to DEXTER units.
Brake Seizure - Front Right Side josephhh Mechanics Corner - Engines, Transmission & More... 15 03-26-2004 11:15 AM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 07:47 AM
Brake Horror Story Mike76251 Brakes & Brake Controllers 4 10-06-2003 12:41 PM
Brake controller hook-up Dimick Brakes & Brake Controllers 7 05-15-2003 09:57 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 02:44 PM
