Old 07-29-2012, 05:50 PM   #1
1962 19' Globetrotter
2001 31' Excella
Globetrotter and Brake Controller?
Getting ready for the maiden voyage of our 62 Globetrotter and I'm not sure if I need a brake controller or not. Any advice or personal experience would be appreciated.
Thanks!
Craig is offline   Reply With Quote
Old 07-29-2012, 06:29 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If you are planning on using the brakes you need a brake controller. Any other arrangement would be either no brakes or full brakes.
Since you also have another trailer I would assume you already have a brake controller in your tow vehicle.
I am assuming you don't mean a brake resistor which used to be used with older controllers for fine tuning. I haven't seen that done in years although I did put one on a horse trailer with 6 volt brakes .
I am also assuming you do have electric brakes, not some hydraulic system?
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
