Old 11-09-2006, 09:11 AM   #29
Originally Posted by paxflyer
Thanks Dan, Yes I do have the 04' F150 Supercrew Lariat (nice truck) and the 1000 lb bars. I should set a video camera up and take her for a ride. The axels and tires make the 25SS appear to have a great ride. The 13 year dog (Golden, who by the does not ride with a seat belt in the truck either) has lots or room in the airstream is never frazzeled. I do have the good govenor voltage and freq monitor. This gen to date been rock solid in freqs and volts, 120V and 60hz.
I do wonder if anyone has moved a electrical plug to the front for this purpose and what problems were encountered?
Thanks to all,
James
It's better done using an adequate extension cord, proper mounted if you want the hookup to be semi-permanent.
Makes the set up much more flexible.
Only problem is inadequate wire size and poor workmanship.
To be super safe, use a #6 extension cord, or you can easily make one.
Security lock for the tongue? Diana Langley Hitches, Couplers & Balls 11 11-19-2002 11:01 AM
Tongue Tied CHRIS CANNON Jacks, Stabilizers, Lifting and Leveling 0 09-30-2002 08:44 PM
Tongue uwe Repairing/Replacing Floor &/or Frame 10 08-27-2002 01:43 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
